07 G35x w/ Eibachs
Old Mar 23, 2009 | 08:16 PM
mattycNJ's Avatar
07 G35x w/ Eibachs
Hey Guys
I recently lowered my G35x w/ Eibachs. I installed the camber kit and everything pretty much is in spec. I did not cut the bumb-stops and the front end is bottoming out like crazy. What is the recommended amount to cut off the bump stops for a G35 X? What are your opinions on ride quality with the bump stops cut??? Thanks
Old Mar 23, 2009 | 08:54 PM
Wes_888's Avatar
what are the bump stops?
I am considering a drop as well. Just havent made up my mind yet.
Old Mar 23, 2009 | 09:42 PM
mishmosh's Avatar
You sure that somethings not loose up front and knocking with large potholes? I did not cut any bump stops (hard foam "bump" material that contacts when strut is fully compressed) and do not get any bottoming. I have a G35S though but it shouldn't matter. Is your whole dash shaking when you "bottom" or are you just hearing a hard knock? When you bottom out, you will definitely feel it through the whole front end and through the dash.
Old Mar 23, 2009 | 10:00 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
they go over the shaft of the shock to prevent bottoming out.
Old Mar 24, 2009 | 01:01 PM
johnnyzee's Avatar
i didnt cut my bumpstops either--08X
Old Mar 24, 2009 | 01:58 PM
G35xQX1's Avatar
nor did i (cut out the bump stops)
Old Mar 24, 2009 | 03:40 PM
G-Driver's Avatar
did mine couple of weeks ago. everything seems to be fine o.O''
Old Mar 24, 2009 | 06:47 PM
soundmike's Avatar
Almost sounds like your shocks are rather worn.
Old Mar 24, 2009 | 07:19 PM
kregg's Avatar
Intgr8r, are you in bump stop sales? That is quite the selection, and what an impressive display.....
Old Mar 25, 2009 | 07:43 PM
mattycNJ's Avatar
I had both struts replaced before I lowered the car. When I hit a marginal bump, I feel it through the whole front end. I have change in my ashtray that bounces like crazy. When I had the stock suspensionm it wasnt like that at all. Also this is not the first vehicle I have lowered. I have had a G35 coupe lowered with Teins, a 2000 TL with comptech springs, and a Maxima with Intrax. This is by far the worst ride I have ever had. I am just frustrated. My car is on the rack now taking a look to see if there is something wrong. Thanks guys.
Old Mar 25, 2009 | 07:47 PM
soundmike's Avatar
It's worth a shot... but is it possible your springs were installed upside-down?
uoftguy
V36 Brakes, Suspension, Wheels & Tires
34
Aug 26, 2019 07:15 PM
reavensf
Sep 17, 2015 11:30 PM
harleydood
Feb 28, 2012 07:47 PM
uoftguy
Feb 12, 2012 07:35 PM
Comatose
Steering & Suspension
Sep 10, 2011 04:59 PM
