Shudder at 40mph (~60km/h)
#216
Good Luck Stevec, i hope you'll be able to demonstrate the problem to the tech. It seems that anytime i'm @ the dealer, the damn thing doesn't shudder!
I actually have a UPRev tuner shop (RT Tuning) about 45 mins away from me. They quoted $300 for the UpRev ECU tune without a DYNO.
I hope that'll help the shudder situation. (though it may actually make it worse, since it resets the throttle sensitivity to "touchy")
#217
So I brought my car in last week to get oil change and mentioned this problem to them... went on a drive and barely produced it but he said he noticed it and will look into it... its been 3 days they haven't called me back, so I called them this morning asking whats up.
They said they will need it to Monday at least, they are having a infiniti tech. come out and look at it? I asked what are you guys planning on doing, they said not sure yet, but they are debating to replace some of the transmission components, or the whole thing.
My question is... should i let them replace the whole tranny just cuz of a little shuddering that can be fix by allowing my right foot to have fun on the gas pedal?
Would this depreciate my resale value? I do want to keep this car for the long run but...replacing tranny effect life of the engine in anyways? (car nub) :P
Suggestions and advice greatly appreciated!
#219
On my 07 G35x, had a hard shift into 3rd gear - 5 spd Auto tranny. My dealer first replaced the Valve Body, then about a year later, in the cold weather, the hard shift returned. Worse in DS mode and worse in Manual mode. They Replaced entire tranny after a road test by the dealer. Warranty work of course. Infiniti Ealer makes $$$$ doing this IF Infiniti approves it. They did, and new Tranny was "popped" in a few hours. I too was concerned, but it cured the ills. Should've Bought that car. Instead I leased a new 2010 G37X. At $20,000 buyout at lease end, only 26k on the clock ----it was big mistake.
#225
