225/50/18 Replace With...??
Old Dec 31, 2009 | 12:33 PM
cokester's Avatar
Ok, so I have 2007 G35 Sedan Journey, with OEM 225/50 R18 tires in front and 245/45 R18 in back. Front tires are 18 x 7.5, rear are 18 x 8.5.
I was able to buy new 245/45/18 for back, but... here in darn Europe it is impossible to get 225/50/18 (for front).
Obviously, I can replace fronts with either:
a) 235/45/18
b) 235/50/18
c) 245/45/18
So... What do you recommend? Looking at all 3 calculators provided on this site I lean toward 235/45/18, but... what do YOU recommend (and why)?
Thanks!
Old Jan 1, 2010 | 03:42 AM
tonke73's Avatar
This is what the Discount Tire sponsor recomended to me. I can live with the increased load capacity for the new sizes. The tire weight is not affected for the fronts and +1 pound per rear wheel is livable using Michelin Pilot Sports A/S.
I would not recommend running 235/50-18s in the front unless you change your rear size as well because it will be taller in overall diameter by 1/2" when compared to your current rear size. I can't tell you why Infiniti chose to run these tire sizes but if you want to change up your tire size you could run 235/50-18s in the front and 255/45-18s in the rear. These dimensions will work on your factory wheel specs. You should be able to run 225/45-18s in the front without any adverse affects on your traction control or ABS, but the tire is almost 1" shorter in diameter and will look akward with 245/45-18s in the rear.
Old Jan 1, 2010 | 03:23 PM
cokester's Avatar
so... since i already bought new 245/45/18 (for back, before i realized i will not be able to get 225/50/18 for front)... you think the best choice (after all is said and done) would be 235/45/18 ?
Old Jan 4, 2010 | 09:14 AM
cokester's Avatar
i located same brand/type like my rear ones... should i go with 235/45/18 ?
11bEMT
May 27, 2022 03:13 PM
ara777
Aug 15, 2018 04:11 AM
snic09
Nov 8, 2017 01:46 PM
miata007
Aug 17, 2015 04:36 PM
35reilly
Drivetrain
Aug 6, 2015 12:40 AM
