G35x AWD sway bar sizing
Old Mar 30, 2010 | 09:54 AM
  #31
bsowhat1's Avatar
Originally Posted by LeD
what do think about using Tanabe rear sway bar instead of OEM?
http://myg37.com/forums/brakes-suspe...amplified.html
The Tanabe rear bar as well as the Hotchkis rear bar (which can be special ordered separately) should fit. Other than the smaller sway size and taller ride height, the rear suspension is identical between the AWD and RWD cars.
Old Mar 30, 2010 | 04:20 PM
  #32
LightsOut's Avatar
SIETESG
good work!
Old Mar 31, 2010 | 06:27 AM
  #33
harp00n's Avatar
Originally Posted by bsowhat1
The rear bars are completely interchangeable.
My RWD bar did not come with bushings so I ordered new ones, Nissan part # 54613-JK01A. The AWD bushings are too small and cannot be used on the RWD bar.
So, if we want to install RWD sway, all we have to change are bushings and we don't need to change brackets, do we?
Old Mar 31, 2010 | 08:23 AM
  #34
bsowhat1's Avatar
Correct.
Old Mar 31, 2010 | 01:24 PM
  #35
G35xQX1's Avatar
great info that you guys have posted up. thanks a bunch
Old Mar 31, 2010 | 04:48 PM
  #36
bsowhat1's Avatar
After more miles, I love the RWD rear sway. I was able to get the VDC to activate on dry pavement for the first time while ripping a corner. After turning off the VDC, car exhibited very neutral cornering.
Old Mar 31, 2010 | 04:49 PM
  #37
bat6wc's Avatar
glad to hear you say that...i just purchased a used one today
Old Mar 31, 2010 | 06:12 PM
  #38
dohturdima's Avatar
^ Me too, only yesterday Hey bsowhat1, where did you buy your bushing kit - part # 54613-JK01A (local dealer, online)? I can't seem to find it...
Old Mar 31, 2010 | 06:23 PM
  #39
bsowhat1's Avatar
I use autopartspeople.com for my OEM parts. Out of Washington state. You will need a pair of bushings.
Old Mar 31, 2010 | 06:24 PM
  #40
dohturdima's Avatar
Thanks, will try them
Old Mar 31, 2010 | 06:52 PM
  #41
InTgr8r's Avatar
Staff ALUMNI (retired)
Originally Posted by bat6wc
thank you!
would def like to see the RWD sway sizes as well...
Sorry this took so long...
FWIW; RWD sport sways
rr = 24.2mm
fr = 26.7mm
Old Apr 1, 2010 | 03:19 PM
  #42
jc68's Avatar
Where did you purchase the stock RWD rear sway bar from? The best price I can find online is around $125.
Thanks!
Old Apr 1, 2010 | 05:06 PM
  #43
bsowhat1's Avatar
I bought mine used.
Old Apr 6, 2010 | 11:05 AM
  #44
dohturdima's Avatar
Is there a difference between RWD Journey and Sport sways?
Old Apr 6, 2010 | 11:55 AM
  #45
bsowhat1's Avatar
No difference
