Linea Corse Lemans Wheels
Old Feb 11, 2010 | 04:55 AM
ofna's Avatar
So I just ordered a set of Linea Corse wheels and was wondering if these are decent specs for a sedan fitment:
Wheel Style - Linea Corse LeMans
Wheel Diameter (Inches) - 19"
Wheel Width (Inches) - 8.5F/10R"
PCD Bolt Pattern - 5x114.3
Offset - 38F/43Rmm
Hub Bore - 73mm
I was thinking about using a 5mm spacer for the rear
or here is the specs for the coupe fitment:
Wheel Style - Linea Corse Lemans
Offset - 15F/20Rmm
Hub Bore - 73mm
there's a first gen sedan using the coupe's offset but he had to roll his fender and go agressive on his camber. I know on our sedans the fenders are already rolled from the factory so maybe all I would need to do is adjust my camber. Also im dropped on the Eibach Pro Kit so the question is which fitment should I go with and what size tires do you guys recommended?
Thanks in advance!!
Old Feb 11, 2010 | 01:40 PM
beezy619's Avatar
I think the most aggressive I've seen on our sedan is a +24 in the rear. heyitsalex is running them. It looks dope as hell. Try the coupe offsets and be the first. I'm pretty sure the sedan offsets will have you close to being flush. What color did you order?
Old Feb 11, 2010 | 07:17 PM
jran76's Avatar
The rear will be fine. You don't need a spacer. You may want to run a 10mm spacer on the front. The fronts will be tucked in more than the rear with those offsets.
My wheels are 8.5" +36 and 9.5" +37 (which is exactly the same as your 10" +43). My rears are flush, but the fronts are tucked in about 10mm with the Eibach drop.
Old Feb 12, 2010 | 12:55 AM
ofna's Avatar
hey beezy I saw you today on Olympic park way I was driving in front of you in my girls white Scion XB....lol, I think im gonna stick with the sedan fitment unless someone can convince me otherwise that it would work without having to roll the fenders anymore than it is. I ordered the gold with polished lip.
Old Feb 12, 2010 | 01:01 AM
ofna's Avatar
Hey jran what size tires are you running front and back and do you have any pictures with them installed? I'm just trying to get an idea of how much of a gap if any.
Thanks
Old Feb 12, 2010 | 07:28 PM
jran76's Avatar
Thanks
245/40/19 and 275/35/19
Pics:
https://g35driver.com/forums/4867977-post6.html
https://g35driver.com/forums/media-s...g-begin-2.html
Old Feb 12, 2010 | 08:25 PM
B L U E S L A T E's Avatar
Honda Accord
Where can you order these?
Old Feb 12, 2010 | 08:26 PM
Honda Accord
Oh btw, do they make them in 20s?
Old Feb 12, 2010 | 08:58 PM
ofna's Avatar
you can order them @ wheeldude.com, yeah I was hoping they made them in 20's but 19's are the biggest they come in
Old Feb 18, 2010 | 11:42 AM
blkdragn's Avatar
Personally, I'd throw a 5mm in the rear and a 15mm up front to have a more aggressive fit. Ive had 19 x 8.5" up front that were +35 and I tried a 15mm spacer and it looked A TAD too aggressive but at +38 with a 15mm spacer it should be PERFECT.
The coupe offsets are way too aggressive, you'd need crazy camber to pull them off.It's definitely not practical, however the end result would be SICK! lol
Mkhlmnn
V36 Interior, Exterior & Lighting
Feb 16, 2016 09:27 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
RAVSPEC
Jul 16, 2015 01:58 AM
