which rotars usually warp first?front,back?
I had to point out to my service writer that there is a tsb for brake judder as he wasn't aware of it. I got a call back 2 days later stating that all the parts were on order and he would call me with they came in.
Did you show them a copy of the TSB? I attached Pg1 of the TSB. I don't see how they can refuse to address this unless they show the cause to be unrelated to the TSB.
Did they give you a reason? Do you have tire, alignment or brake pad problems that could be causing the judder?
ITB09-037b-pg1.pdf
ITB09-037b-pg1.pdf
Attachment 123251
Attachment 123251
thanks so much for the tsb i wil print it out and take it to them and see what they say
Don't be so sure... I had the TSB in hand and the service manager still would not do it (called brakes "wear and tear" items). I e-mailed Infiniti of America and then the dealership's service supervisor called me and told me rotors will be resurfaced under warranty.
I just emailed them today with the tbs report.... im still waiting for a reply ,if that wont work does anybody know if the sport rotors from stillen warp as easily as the stocks? will slotted rotars cause more noise in braking?
these are the rotars i was thinking of http://www.stillen.com/product.asp?i...NITI&model=G35 4DR
Nick_M
08-03-2015 11:08 PM
Nick_M
08-03-2015 05:33 PM
