Can i Run 255/40/19 all around?
Old Oct 18, 2010 | 09:02 PM
BlueFlash's Avatar
Currently I am running 245/40/19 dropped (slight tuck in rear) without an issue. I am sitting at et38 all around.
Do you think that I am safe with 255?
Visually it looks like there's room but I wanted your opinion,
thanx
Old Oct 18, 2010 | 09:13 PM
HenryLee's Avatar
how size width are your wheels?
Old Oct 18, 2010 | 10:03 PM
BlueFlash's Avatar
x8.5 why?
Old Oct 19, 2010 | 05:40 AM
Defratos's Avatar
You're Despicable
you should be fine with even 275s in the rear,
As for the fronts, when I first got my rims they had 255/35 on all four rims. Which was fine but I ended up scrapping the bottom of my car when I go in and out of my driveway.
So I changed the fronts to 245/40 I believe and 255/35 in the rear and it's perfect for me.
I've got 19x9" Yokohama Advans ET25 all around.
At first I ran 275/35 in the rear, and they didn't rub at all, but they did stick out more than I wanted.
Recently I changed these to 255/35 and it's perfect for me, especially the ride and handling characteristics, much better than with 275s.
Personally I don't see why you'd have ANY rubbing issues.
Old Oct 19, 2010 | 05:44 AM
TIRE_SMOKE96's Avatar
40 is going to look tall.
Old Oct 19, 2010 | 08:45 AM
soundmike's Avatar
I'm not sure how different my drop is from yours, but i'm running 255/40/19 on +35 wheels all around. I have had no issues with rubbing or anything weird with this set-up.
Old Oct 19, 2010 | 04:45 PM
LightsOut's Avatar
SIETESG
just add a little more camber, thats all.
255/35 tire will be a good size
arent you on BC's? if so, just raise your ride.
Old Oct 19, 2010 | 04:48 PM
LightsOut's Avatar
SIETESG
Originally Posted by BlueFlash
x8.5 why?
with a wider wheel, you can get a stretch that allows for a better fitment.
Old Oct 19, 2010 | 09:36 PM
BlueFlash's Avatar
i already run a 40 sidewall, i have an x, so 255/40 is a must.
soundmike, do you have a closeup of your tires? also, what wheel width do you have?
Old Oct 20, 2010 | 08:48 AM
soundmike's Avatar
They're 19x8.5 (+35) all around. These are all i have at the moment, but if you'll let me know which angle you want the shot of, i'll do it when i get home.
Pic 1
Pic 2
Pic 3
edit: When i had the fronts lower -- pretty much tucked-in -- at maximum compression, combined with a hard turn, i did hear some rubbing but could not verify where it was coming from. At the current height, i've had no issues whatsoever.
Thebaws11
Jul 2, 2021 11:36 AM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
Thebaws11
Nov 30, 2016 12:54 PM
Vqalexisz
Oct 14, 2015 12:48 AM
n2fooz
Sep 4, 2015 07:46 PM
