What TPMS Reset Tool to Buy?
I am not sure if anyone is still trying to figure out what works for their TPMS. I am using Blizzaks winter tire/wheel package with TPMS from Tirerack in the winter and OEMs with oem TPMS the rest of the year and I have not had issues when swapping between wheels on my 2004 G35. Tire light does not stay on.
I do not have to reset anything or procedure to follow. just swap wheels and done.
So I am clear, this tool reads the id without the requirement of any additional tool required?
From amazon:
2 of 2 people found the following review helpful
2.0 out of 5 stars
Frustrating, tedious, but works
November 5, 2012
By Gringo
I'd really give it 1-1/2 stars. Bought two years ago for 2009 Hyundai Santa Fe to allow me to change from summer to winter tire/wheel set.
Installed software on a laptop with Windows XP Pro, SP3. Software & USB drivers are not digitally signed, so Vista and Win7 won't like it much. Software is worst part of this operation (see below)
Ateq tool can read your current TPMS sensor IDs from the vehicle computer via the OBD-2 connector, and you can store them in a "summer" or "winter" wheel set in the software. However, you must know the correct TPMS sensor ids (in the correct position) for your new wheels to enter in to software, as this Ateq tool will not put vehicle TPMS system into "learn" mode. (As I learned, this is something the Hyundai dealer can do, for $80-100 a pop, but many independent mechanics and tire centers could not).
Once the correct TPMS sensor IDs are entered, you can fairly easily swap from summer to winter tires. However, the software is very kludgey and has idiosyncrasies like needing a live internet connection and the Ateq tool connected to USB to "verify" installation, or it won't run (prospects not good, if Ateq decides to take their server off-line). It also constantly checks for non-existent software updates (none in the two years since installation). User interface is very poor and I constantly need to minimize and maximize windows in order to get dialog buttons to respond, and occasionally need to restart completely. Dragging the tires in "free rotation" mode is problematic and tedious. "Swapping" tire positions also moves one tire, while erasing the code of the other one. (Need to use native Windows screen shot or write down codes manually, as there is no print option in software). On the plus side, the on-screen instructions for reading old codes via the OBD-2 connector and writing new ones to the vehicle computer seem to be correct, if followed.
Bottom line: it's not good, has a steep learning curve, but I got it to work on my Santa Fe. Now I swap my tires at will, without needing to go to the dealer to get the TPMS reset. It takes nearly as long to mess with the software as it does to change the wheels, but that's still less than half the time (total) I'd spend to have someone else do it. After two swaps, it paid for itself. If you can find a better solution, buy it. But, if you're desperate and stubborn, this can work.
on
You can pull down the current IDs via OBDII and set as summer/winter
You can manually enter the IDs for the other or pull those down once they are programmed on the vehicle (by dealer, tire shop, etc).
Once you have both sets stored in the tool, you simply plug it into the vehicle, click the summer or winter button, that's it.
For 95% of imports, no additional tool is required.
Ok, if you're saying what I think you're saying ...
SO . . . as I understand it, essentially you are confirming that unless you know the ID's of the (new or replacement) set youself, you will need to have them read and/or initially programmed by the dealer or a well equipped tire shop for you, BECAUSE THIS WON"T LEARN THEM for you; they must already have been programmed into the TPMS system for this device to read them . . . meaning you MUST initially get the ID's established from some other additional tool/ equipment. ISN'T that right?
My point is that an unsuspecting person could have a summer set on currently, and a loose winter set which hasn't been programmed in yet, and think that by buying this tool they will have everything they need to complete the job, which is not, in fact, the case.
Please correct me if I am wrong, and I will gladly edit and retract this post. I understand switching back and forth between sets is all good with the device once you get all the IDs, it's for the initial configuring that I'm questioning the requirement for additonal equipment here.
on
**SIGH**
What you stated above is one way to get the IDs for your extra set of wheels into the tool. The other way is having the sensor ids documented and manually entering them into the tool (read: type them in). Some dealers store these numbers for you in their system OR write them down for you before they install them on the wheels. If the dealer doesn't have the IDs AND didn't give them to you before installing the sensors, THEN they will have to go your route.
Make more sense?
#30
Yes, so if the average guy buys a used set of wheels with sensors, and does not get the documentation of what each ID is for each wheel, a very common scenario, then they will need more equipment than this tool alone to complete their installation. Thank you for the heads up.
