Eibach Springs
Old Jun 21, 2011 | 09:16 PM
jnova's Avatar
Eibach Springs
What's up everyone?
I'm ready to drop my car. I'm going with the eibachs pro kit, I guess there is some mixed opinions out there. At any event, before I purchased these springs, I'm sitting on 20" TSW Snettertons with 245/35 tires... With stock specs offset, I'm worried that I'm going to rub, and more less I'm worried about the camber settings... Can anyone out there tell me what the settings are for our cars... I have owned GTI's, SE-R, SRT-4, and EVO 8, and all have been dropped using springs, but never did anything about camber kits etc... Any imput will be greatly appreciated.
Thanks
Old Jun 21, 2011 | 10:13 PM
black_sedan's Avatar
what wheel offsets you running? Im running TSW Jaramas and lowered on Tanabe NFs. I have the same tire size but my wheels are 20x8.5 38mm offset and I have no issues with rubbing. As long as its not a low offset or staggered you'll be fine.
Old Jun 21, 2011 | 10:53 PM
jnova's Avatar
Offset is 40mm And they are 20X8.5 all around... I want to know about camber settings?
Old Jun 21, 2011 | 10:57 PM
dsgb73's Avatar
Veteran: Navy
I'm running 20" Velocity 840s and lowered on Eibach Sportlines. My wheels are also 20x8.5 with 38mm offset. You will be fine. The Sportlines drop is more than the Pro kit so if you have a lot of speedbumps or potholes where u live, you may want to be a careful if u go with the sportlines.
Old Jun 22, 2011 | 06:22 PM
jnova's Avatar
I don't want to go with the sportlines... I've had those before... Nice springs but too low. I want to try to stay as close to confort level to stock and the pro kits r not as aggressive. I was just worried about camber/toe specs
Old Jun 22, 2011 | 07:21 PM
lefizzet's Avatar
Once you get springs you're gonna be tucked and could use a 15-20mm spacer for it to be flush. I have rear kit only no fronts and I get aligned within spec for the most part.
Old Jun 22, 2011 | 09:40 PM
jnova's Avatar
So... I guess what I'm reading is that, I need to get the car aligned as closest to factory specs? But I don't know what those specs are?
Old Jun 23, 2011 | 08:55 AM
Swagger_Jacker's Avatar
Im dropped on the pro kit sittin on 20's no issues. nice ride after a few hundered miles. Only issues which im working with infiniti on is i have auto leveling headlights and mine are now pointed at the ground because it thinks the back of the car is heavy.
Old Jun 23, 2011 | 02:39 PM
lefizzet's Avatar
You don't, but the software/mechanic does
Old Jun 23, 2011 | 11:31 PM
jnova's Avatar
Any more imput? Bump
Old Jun 24, 2011 | 12:25 AM
lefizzet's Avatar
What else do you want to know? You will NOT RUB 100% guaranteed. Ride is obviously going to be harsher than stock since you will be dropped and riding on 20's.
Old Jun 25, 2011 | 01:14 AM
bertmauricio's Avatar
Here is a post on the alignment specs. Your alignment shop will provide you the details and will probably recommend rear camber arms.
https://g35driver.com/forums/5763448-post19.html
Old Jun 25, 2011 | 04:10 AM
NATH_19's Avatar
Just got my car lowered with 19" OEM rays...Eibach Sportlines with 20 spacers at the back and 15 front with no rubbing issues.
Had a camber kit at the back ( higly recommended ), I bought the Ichiba brand for $110 a pair, I suggest let the springs settle in first for 2 to 3 weeks depending on your car usage and then get an alignment.
Ask the shop mechanic what is the OEM specs for your car and if he scratches his head...go to a different shop.
They should know and it should be programmed in their computer alignment system...you can even tell them to print the results for you.
Old Jul 27, 2011 | 02:57 PM
botlfed98's Avatar
pics?
Old Aug 1, 2011 | 09:13 AM
Kamikazejs's Avatar
Subscribed.
DRG35R
Jan 31, 2016 07:14 AM
Rose M
Oct 12, 2015 10:00 AM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
Chauzilla
Sep 27, 2015 04:34 PM
