pic/ spec request
Varrstoen? +22 should be fine with that 245. PS you can stagger AWD. Myself and many others have already done it. Take a look at the link below to get an idea. Bring the front in 10mm and the rear would come in 13mm compared to the pic.
http://varrstoen.com/blog/?p=1596
visually, diameter difference doesn't matter at all. its the difference what your speedometer shows and that actual speed you're traveling at that matters. for example, the 255/40/19's have a diameter difference of 1.08%, so even though you may be traveling at 60mph, your speedometer will show 59.3 mph. as you get further away from stock diameter, the difference will increase.
That's correct. It would stand up a little taller on an 8.5" wheel. But we're just saying it doesn't matter if it's shorter or taller. It's only gonna affect the looks and the speedo like ajkVQ said. Don't worry about OE diameter.
