Rack and Pinion Leak
Old Feb 27, 2020 | 12:19 AM
Terence Wong's Avatar
2005 Infiniti G35 Sedan RWD automatic
My rack and pinion looks like it leaking from the boots of both tie rods. Is this fixable or do I need to replace the whole rack and pinion? Also does the bolt next to the driver side tie rod leak? If so I think that might be what’s leaking instead. Just hard for tell if it’s splatter from the boot or just leaking from that bolt.
Old Feb 27, 2020 | 10:12 AM
Urbanengineer's Avatar
You can swap it with an eBay reman, you'll need an alignment after.
Old Feb 27, 2020 | 11:06 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Is the fluid level in your power steering reservoir dropping? It might not be a power steering rack leaking but rather a component above it. I've had limited short term success with power steering fluid leak stopper. Use a turkey baster to suck fluid out of the reservoir and replace with stop leak. It'll buy you a few months and give you time to replace the unit, I've never seen a pump damaged by power steering fluid stop leak.
Old Feb 27, 2020 | 06:40 PM
what’s an eBay reman?
Old Feb 27, 2020 | 06:42 PM
Anyone know if this bolt specifically leaks at all? If so I think that might be what’s leaking
Old Feb 27, 2020 | 07:39 PM
cleric670's Avatar
BANNED!!!
That's the adjustment nut for setting the pinion rotating torque during initial assembly. I don't think there's a seal behind it but I haven't had the R&P for this vehicle taken apart (yet...), I do know it's common practice for there to be threadlocker on it to keep it from turning and help seal it.
Let me ask you a question, does your steering feel REALLY loose? It's possible you already have a remanufactured unit and they didn't apply thread locker and it's backing off, your steering would feel super loose though, there should be a little bit of resistance to it but the generic rule of thumb for "drive adjusting" the R&P is you tighten it up to the point where the car will still straighten itself normally through a slow corner. If it doesn't try to straighten itself quickly it's too tight. If it snaps straight super fast it's too loose.
You can sort of eyeball that value by lifting the front of the vehicle up and feeling how much tension is on it with the engine off while you turn the wheel. Should be some drag but not much.
However if you're leaking from the side seals as well then you just need to either rebuild the unit or buy a reman(ufactured) one.
Old Feb 27, 2020 | 11:03 PM
that’s interesting. I’m guessing that bolt isn’t the problem then cause when I turn, it’s actually a little hard but not too hard. I have a Q50 also and the turn for that car is smooth. I’m guessing it’s probably the side seals then so I’ll just replace the whole thing. Thanks for all the info. Much appreciated
Old Feb 28, 2020 | 11:35 AM
cleric670's Avatar
BANNED!!!
Another cause for stiff steering is the u-joint going into the R&P gets old and starts to bind up. You should spray it down VERY HEAVILY with some kind of lubricant like WD40 and see if your steering loosens up. If so then you should plan on replacing that u-joint when you put in the new R&P, it's really easy to do them both at the same time.
alwayson
May 8, 2015 07:09 PM
Michaelh90
Jun 17, 2013 09:24 PM
Choleaoum
Dec 11, 2010 01:22 AM
Marlin
Nov 15, 2009 12:14 AM
Marlin
Nov 12, 2009 04:51 PM
