DIY: Philips 6000k Ultinon Install
OK so I received both of the 6000k philips bulbs in the mail today so I figured I'd install them and take some pics along the way to help out other people interested in doing this mod.
This is what the Philips 6000k Ultinon bulbs look like:
Tools Needed:
2 new 6000k Philips Ultinon D2S bulbs
1 tire iron (plus tire lock bit)
1 flat edge screwdriver
1 garage jack (or stock jack if you want to work harder)
First you'll want to loosen the lugs on the tire of the side you'll be starting on. This is necessary to do before lifting up the car. Jack up the car just high enough to be able to remove the wheel.
After doing this you will see a plastic panel lining the inside of your wheel well. The opening for the projector headlight is behind this panel.
On this panel you will find about 6 (maybe 7 I forget) little plastic tabs. It is necessary to remove these tabs so that you can peel back the wheel well lining to gain access to the headlight opening.
Once you get this removed you will discover a circular weatherproofed "lid". This must be unscrewed to gain entry to the bulb you want to replace.
Once the bulb is located you will need to remove the wiring harness from it. To do this you simply turn it counter-clockwise. It will move a notch, and then you can pull it away from the bulb. To remove the bulb itself you must pull two little butterfly pins out of the grooves in the bulb itself. It's hard to explain but it's pretty self explanatory once you see the pics below.
It is important not to touch the glass on the bulb. The oils on your hands will heat up the glass when in use. This will destroy them. If you touch them by mistake you'll need to clean the glass with rubbing alcohol before using them. I took my OEM bulbs out and placed them in the container the new bulbs came in. I'll store them.
Install the new bulbs by following these directions in reverse. Turn on the headlights and test them out before buttoning everything up. .
This pic shows the difference between the OEM bulbs and the new ones. I think the camera made the bulbs look a tad bit bluer than they actually are in this pic, but I promise you it is not ricey or obnoxious.
Here's the finished install. I think it looks pretty slick.
Tools Needed:
Great post, thanks as I was considering this. Do you feel those bulbs are any brighter? have longer throw? or are easier to see with at night? or is is just the color change? My parents have Audi's which are much more blue then mine and I find I can always see better at night with their headlights. wasn't sure if it's the color of if they have more powerful ballasts or a better projector lens.
Originally Posted by 07 G35S Sedan
Excellent write up... Did you notice any reduction in visibility? I heard often times when you update to a higher rated bulb in tends to compromise overall lighting.
Lastly my car is lowered and now it seems I'm out driving my lights. Is it simple to adjust the headlights?
Regarding the headlight aiming, I would like more info on that too. The G's come stock with the left lamp aimed down a tad (so you don't blind oncoming traffic). I'm going to see about raising it up a little bit. I know there's an alignment screw somewhere.
