DIY: Clutch Fix #2 - Oh what a feeling :)
Old Sep 23, 2010 | 03:07 PM
  #91
nasman3188's Avatar
i haven't had any issues with my 06. The spring has been out for about 4 months.
Old Sep 23, 2010 | 09:31 PM
  #92
kool_yaar's Avatar
iv had it for a year now and no problems here
Old Oct 11, 2010 | 11:00 PM
  #93
G force's Avatar
I put a 2-penny bump stop at the top of my clutch (not the bottom) and it cleaned up the lose play from taking the spring out, very happy with it now.
Old Feb 9, 2011 | 07:51 PM
  #94
Ozzfest's Avatar
Is it necessary to do clutch fix #1 before the removal of the spring?
Old Feb 9, 2011 | 10:50 PM
  #95
Roadtrip's Avatar
No. the two mods are independent of one another. As i recall, the first mod is one to reduce excess pedal travel.
I have done both mods. I actually did spring mod first, then reduced pedal travel with shims behind stops (I used 4-5 pennies taped together with two side tape as temporary shims to see how I liked it and. well, they are still there today, a year or so later.
Old Mar 23, 2011 | 01:52 PM
  #96
GSoccer24's Avatar
I did it today and really like the feel compared to stock. The only thing that stands out to me is that it feels like the clutch engagement area within the stroke of the pedal is in the last 20% of the pedal stroke.
Old Mar 23, 2011 | 04:19 PM
  #97
kool_yaar's Avatar
this mod should not affect the engagement area at all but would only make it easier to push in and out, as is stock the G's have a really high(from floor) engagement point than most cars, i like it when changing gears quickly.
Old Mar 23, 2011 | 09:59 PM
  #98
TomPeters's Avatar
For the people who are complaining about the play when the clutch is fully released there are two quick fixes. If you look up above the clutch pedal you'll notice a white rubber stopper that is supposed to be snug to a black switch above (just wiggle the clutch and you'll see where these parts are). The switch is the ASCD clutch switch and its function is to disengage the cruise control once the clutch is depressed to prevent overreving of the motor.
1) There is a nut you can loosed on the threaded part of the switch and then adjust the sensor so it snugs up to the stopper. Once the switch is in the proper spot you just snug up the nut you first loosened. (proper way)
2) Add 1/16" piece of material (rubber shim/penny/whatever) to the existing factory white rubber stopper with double sided tape. (jimmy rigging way)
Both of these are doing the same thing in theory. Best/fasted mod for this car. Enjoy!!!!
Old Mar 26, 2011 | 06:58 PM
  #99
MANSU_V36's Avatar
did this mod one month ago, now even my girl friend can drive with out stalling out.
Old Sep 6, 2011 | 06:56 PM
  #100
serges's Avatar
Ok i have a 06 coupe mt and i just dont understand how this is done i can barely see the spring and i dont understand where u put these pennies im sick of driving like a idiot when i knew it wasnt me i have drivin mt cars for ten years straight never had this problem please help
Old Sep 6, 2011 | 07:19 PM
  #101
kool_yaar's Avatar
Well this DIY is specifically for the 2nd gen Gs (2007+) so that could be why you cant see the spring, might be a different design or location. Search on google for a similar DIY for 1st gen Gs or post some pics of the clutch area and maybe we can help spot the spring assembly if it has one. On the side not even with the spring the car is not hard to drive but requires a smoother foot movement for 1st gear which this mod fixes, rest is the same with or without spring for me.
Old Sep 19, 2011 | 12:14 AM
  #102
AARONHL's Avatar
Does this mod help with the squeaking on 1st Gen?
Old Sep 21, 2011 | 11:46 AM
  #103
dmarz45's Avatar
Does anybody know what size wrench you need to adjust the clutch rod?? I want to move my clutch pedal up a little bit to bring down the engagement point a little bit. The engagement point on mine is like right at the top of the pedal after doing this mod.
Old Sep 21, 2011 | 10:12 PM
  #104
rmyc's Avatar
Def answer need??
This works with 1gen?
Old Sep 21, 2011 | 10:19 PM
  #105
dmarz45's Avatar
Originally Posted by rmyc
Def answer need??
Yeah I did it with my 1st gen. works great. Just need to adjust the extra play in the clutch afterwards.
