DIY: Clutch Fix #2 - Oh what a feeling :)
Old Oct 8, 2011 | 10:49 AM
  #106
NYT's Avatar
NYT
Originally Posted by mishmosh
This pic is from the 1st gen clutch takeup adjustment mod. Isn't that the spring in the pic. In ours it is kind of perpendicular to the clutch rod--in this pic, it looks like it is parallel--if that is the clutch spring that is.
BTW, this 1st gen mod will not work with our 2nd gens. I think with Ian's DIY clutch fix #1 and #2, you will be very pleased though.
I have a 1st Gen coupe. Can I remove this spring AND do this clutch takeup adjustment?
I've already done clucth fix #1 (well I just added 2 pennies) and I want to ensure none of these 3 different types of clutch adjustments conflict.
Old Feb 25, 2012 | 05:18 PM
  #107
homer_atl's Avatar
hi guys. i did this mod on my 08 sport. worked great right after i removed it. Pedal stroke felt almost identical to stock... maybe 1/4" more of slop at the top... but after a day, seems like the pedal stroke got shorter... so there is about 1" of slop at the top and barely any travel w/ resistance. So it's not the same as the first day. What's going on? is there a fix for this? Thanks.
Old Apr 23, 2012 | 01:09 PM
  #108
Wannabe6MT's Avatar
-MN G Crew-
After contemplating this mod for awhile, i finally did it this morning. After some struggle getting the clip off the end of the spring, i got it out.
Took it for a drive and immediatly noticed a difference. It is a smidgen harder to depress now, but not that bad, and the feeling is extremely different. Way more linear now and feels like a clutch should feel.
Im hardcore not used to it, but im gonna drive the car for awhile and see if i get used to it.
Old Apr 23, 2012 | 01:16 PM
  #109
jsolo's Avatar
For those that have removed their spring, can you do me a favor and take a measurement of the free length, and inner diameter.
The pics in the first post look very similar to the pedal setup in the 370z/g37 6mt's. I set up a group buy for replacement weaker springs on myg37 for those that still wanted to have some spring force to push the pedal back up and to eliminate the slop/play present at the top of the pedal when no spring is present. See http://tiny.cc/9t87cw if interested.
Old Apr 23, 2012 | 10:33 PM
  #110
NYT's Avatar
NYT
I'm interested if you want to do this for the G35 too.
Old Apr 23, 2012 | 10:43 PM
  #111
jsolo's Avatar
^^Sure thing. From the pics i've seen of the 2nd gen g35 pedal, it appears the same, but it's important to confirm.
To pop the spring out takes all of about 30 seconds and a pair of needle nose pliers to remove the LOWER (no need to pull the upper) C clip. Using vernier calipers or similar, take a measurement of the above two parameters.
Thanks!
Old Apr 24, 2012 | 01:40 AM
  #112
vqsmile's Avatar
If I get a break tomorrow morning, I may pop mine out and see what they measure.
Old Apr 24, 2012 | 11:26 AM
  #113
jsolo's Avatar
Thanks! Looking forward to it. I'm 99% sure they're the same as I recall I had one guy with a g35 buy one last time. Or perhaps he just had g35 as part of the screen name
Old Apr 24, 2012 | 12:11 PM
  #114
vqsmile's Avatar
Ok, so I just measured the spring with my trusty dial caliper and came up with the following measurements for my factory spring:
Free length = 61mm or 2.40"
Outer diameter = 31mm or 1.22"
Inner diameter = 22mm or .865"
Spring wire diameter = 4.3mm or .17"
Total number of coils* = 7
Number of active coils* = 5
* per reference: http://www.planetspring.com/pages/co...calculator.php
I also measured the diameter of the spring perch/seats and came up with approx: 21.5mm or .845"
Old Apr 24, 2012 | 12:21 PM
  #115
jsolo's Avatar
vqsmile,
Thanks for confirming and including *all* measurements
This is indeed the same spring as they used on the later models. Mainly what I was after was the ID and the free length. The replacement spring is slightly longer by .10", but works just fine. The ID was important because too small and the hat won't fit inside, and if too big, it may shift when the pedal is depressed/released.
http://tiny.cc/8w22cw
Your car is a 2nd gen g35 6mt, correct?
Old Apr 24, 2012 | 01:03 PM
  #116
vqsmile's Avatar
Yep, 2007 G35S 6MT
Old Apr 25, 2012 | 09:18 PM
  #117
NYT's Avatar
NYT
Anyone tried this yet... any reviews?
Old Apr 25, 2012 | 10:57 PM
  #118
kool_yaar's Avatar
^?? ... this whole thread is about ppl who tried this and posted reviews, read the pages. and since u have 07 coupe it may be a bit different.If you are talking about replacing the spring then its about the same thing but a weaker scale
Old Apr 25, 2012 | 11:03 PM
  #119
vqsmile's Avatar
Seriously ?????????????????
Old Apr 26, 2012 | 12:11 AM
  #120
jsolo's Avatar
Btw, UPS says delivery tomorrow, so keep an eye in the for sale thread.
