DIY: Rear Differential Oil Change
Complete how-to with pictures (and links to larger ones) on my site.
Steps:
1. Jack up the vehicle, or place it on ramps. The more you can get the car level, front-to-back, the better it is for draining the old fluid and gauging how much new fluid you have. I personally placed the vehicle on four jack stands, two front and two back.
2. Loosen the fill bolt on the passenger side top section of the differential.
3. With a catch container below the differential, loosen the drain bolt and remove. Drain all fluid.
4. As the fluid drains, clean both bolts. The drain bolt has a magnetic tip and you will likely see a lot of gunk/metal flakes stuck to it. Attach new washers as needed (recommended, per the FSM).
5. When the differential is completely drained, re-attach the drain bolt and torque down to 26 ft/lbs.
6. With your method of fluid transfer ready to go, start pumping new fluid into the differential through the fill bolt. We use a fluid pump here, about $10 from your local hardware store. If you get it from Sears, as i have, it’s in the Outdoor/Lawn Mower section. An entire bottle can be transferred in just a few easy pumps. A tip on the pump, the hoses that come with this is rather stiff, it may be worth your while to temporarily zip-tie or tape it near the fill-hole so it doesn’t move or accidentally come off while you’re pumping.
7. As the differential fills-up, you’ll notice some fluid will start overflowing and trickling down. This is a sign you are done. Remove the pump/tubes and let it continue to trickle.
8. Once it stops, attach the fill bolt and tighten to 26 ft/lbs.
9. You are done
Nasty stuff! This fluid only has 30k miles on it.
Steps:
9. You are done
^ what he said
On our model year FSM, 80w90 is recommended. But later years have 75w90 spec'd out, so i figured any of the two would be fine and went with what was readily available at our local Autozone.
thats non X but same as X rear, front diff service is exact same steps but in front, if you can do this then its the same but maybe a little cramped for room.
^ Looks exactly like this -- http://www.harborfreight.com/multi-u...ump-66418.html
It's a bit cumbersome to use as the tubes are fairly stiff, but it works.
If you have an X the front is a bit more hidden
