DIY: Quick 'n Easy Power Steering Fluid Change
Old 07-04-2012, 08:01 PM
vqsmile's Avatar
Originally Posted by rvanderwerf
... Keep in mind our cars need Dextron VI grade ATF, and the pictured Mobile 1 shown above meet minimum specs (although it may have on earlier G's).
I was wondering about this. Can you refer me to a where I can find this in writing from a factory source? Thanks.
  #47
Old 07-07-2012, 01:26 PM
Rollo's Avatar
This was the easiest DIY ever...I am mechanically challenged and even I pulled it off. Bought a little fluid transfer pump from Advance Auto and it worked great.
Thanks Mike!
soundmike (10-21-2012)
  #48
Old 09-09-2012, 04:48 PM
behemoth1's Avatar
Flush video & optional filter install
Full flush video with optional filter install.
http://x.infinitihelp.com/forum/show...line-3157.html
  #49
Old 10-21-2012, 06:41 PM
RedBaronK's Avatar
Props to OP... easiest DIY ever and cost me 23 bucks Inc fluids and a pump. Beats stealership 100 dollar cost hands down!!
  #50
Old 11-20-2012, 02:44 PM
Anton_Chigurh's Avatar
doing this today...mine is like black and i have had steering issues when cold..wonder if it's related..we will see
  #51
Old 11-20-2012, 04:38 PM
welp..not doing it today since it's dark out at 330 now so it will have to wait until next week...**** that
and also...you use ATF for power steering fluid? I have generic power steering fluid in my garage that will work won't it?
  #52
Old 09-28-2013, 08:01 PM
Osa713's Avatar
Old thread but great results. Thanks to the op
  #53
Old 09-28-2013, 08:31 PM
soundmike's Avatar
You're welcome.
  #54
Old 09-20-2014, 04:04 AM
eswift1983's Avatar
Sorry for the bump but would this work for transmission fluid somewhat? I know you would have more trouble getting it out (I'm thinking tube down the dipstick) and yes you would have to use a LOT more fluid to ensure you get most of it changed but I feel like it would be SO much easier. I dunno.
Newbstyles lol
  #55
Old 06-09-2016, 03:50 PM
Ferinthul's Avatar
Originally Posted by malton
I flushed my power steering today and after noticing the fluid wasn't getting "clean" as fast as I had hoped I decided to figure out how many times it was going to take to replace most of the old fluid. The graph below is what I came up with... This assumes the old and new fluid mixes completely between each exchange. Hope it helps.
Also I used a brake bleeder bottle and a syringe to syphon the old fluid out of the reservoir. The syringe is only needed to start the process. It is a bit slow but leaves virtually no mess.
graph literally means nothing, not account for the old fluid removed in the beginning. You start with a higher percentage.
  #56
Old 06-09-2016, 04:48 PM
vqsmile's Avatar
True enough, but that post was over 5 years old.
chinee
06-10-2024 07:48 PM
NemesisGee
08-11-2015 07:10 PM
keithk831
Steering & Suspension
08-02-2015 09:50 PM
Quick Reply: DIY: Quick 'n Easy Power Steering Fluid Change
