i have an 07 g35 sedan and im interested in adding on a exhaust system between 500-800$. any information would be helpful,
thanks.
thanks.
a.k.a kleicoupe
Don't know if you can get an exhaust for that price.
But you should look at fast intentions, and I think stillen has an exhaust for the 07 sedans too.
gary c
close
- Join DateFeb 2005
- LocationValencia, Ca
iTrader Positive Feedback100
iTrader Feedback Score(10)
Liked:1,133 Times in 1,003 Posts
Quote:
thanks.
Not sure if you'll find an exhaust that cheap, quality cost $! Give Chris a callOriginally Posted by themofo
i have an 07 g35 sedan and im interested in adding on a exhaust system between 500-800$. any information would be helpful,thanks.
at Magnaflow 1-800-990-0905. You can also listen to the Magnaflow sound
clips @ www.magnaflow.com under imports. Fast Intentions is a quality system but the cost is almost twice what you intended to spend....Good Luck!
Gary
well, do you think i can fit an exhaust for the older body coupes on my car or its not gonna work
No way if it is a stock exhaust. And even if you are referring to an aftermarket one ... I have a feeling the hanger locations will be different because of the newer body style on the 07.
If you are going to do it, do it right and get a good exhaust. May cost you a bit north of $1k but if you are going to spend $800 just spend the extra and do it right.
I would look at either the Stillen system or the Fast Intentions exhaust. the FI exhaust with HFC's sounds fantastic
If you don't want to go with the names that have been listed, you can just go to your local muffler shop, a decent shop should be able to mandrel bend pipes and sell mufflers, definitely not the same r&d as with the name brands listed, but it's probably the cheaper route to go...
and since you're in socal, mufflers shops are aplenty
i have universal muffler tips already on my car, plus i straight piped it, but it doesnt seem to make alot of difference as far as power is concerned. im also thinking about installing headers too
oooorrrrrrrrrrrrrrrrrrrrrrrr... you can always check the market place or on these forums for someone selling a stillen o r fast intentions. Some people put them on and it ends up not being what they expected and try to sell them to other members... just an idea cuz you wont find one brand new for under 1g.
Quote:
what's the diameter? if you use stock size diameter, you probably won't see any difference...Originally Posted by themofo
people here have had some gains (like 10 whp or something) using hfc + exhaust
does anyone make headers for the current gen?
Gary
The two people I always find good deals thru are www.hottexhaust.com and www.planetmagnaflow.comOriginally Posted by gary c
Not sure if you'll find an exhaust that cheap, quality cost $! Give Chris a callat Magnaflow 1-800-990-0905. You can also listen to the Magnaflow sound
Gary
B L U E S L A T E
close
- Join DateApr 2007
iTrader Feedback Score(15)
- My RideHonda Accord
Liked:80 Times in 65 Posts
Post some pix of your straight pipe (test pipe?) and the exhaust tips.
