"Unbolting" exhaust
Old Aug 19, 2008 | 08:54 PM
MtreyM's Avatar
"Unbolting" exhaust
I saw on a YouTube video that the guy who made the video "unbolted" his exhaust on his 08 G and said it only takes 15 minutes to do. I was wondering if anyone else on the forums has done the "unbolt". I guess its basically a straight pipe effect.
Old Aug 20, 2008 | 02:50 AM
terrycs's Avatar
Yes, I've seen it done on my car, but the car was on a lift.
EDIT: oops, my bad ... I thought you guys were talking about how long it takes to pull the exhaust out.
Old Aug 25, 2008 | 07:59 PM
Cali G's Avatar
That was my video I'd imagine... Just look under the car, you'll see the clamp that connects the mufflers to the rest of the exhaust... just unbolt it.
Old Aug 25, 2008 | 08:10 PM
titan13qb's Avatar
will that bring up any warning lights??
Old Aug 26, 2008 | 11:12 AM
LiquidGx's Avatar
Shouldn't, unless you unbolt it before either o2 sensor on either side.
Old Aug 26, 2008 | 10:14 PM
g35_6gear's Avatar
I unbolted mine tonight and I was surprised at the sound. It was louder but mellow, not raspy at all. Sounded quite good IMO. No check engine lights to report.
Old Aug 26, 2008 | 11:56 PM
d280c's Avatar
Any performance increase, what about the gas pedal "feel" with less back pressure?
Old Aug 27, 2008 | 01:52 PM
g35_6gear's Avatar
It seemed to breath a little easier for sure...especially past 4000 rpm's. Dyno would be only way to tell for sure. Idle was a little lower and loped a little more than with the exhausts on.
Old Aug 27, 2008 | 02:42 PM
silverG2007's Avatar
Louder exhaust makes your car sound faster.
Unbolting may be good for 5-10hp. Not much different from a catback exhaust.
Old Aug 28, 2008 | 06:17 AM
Borna's Avatar
Anyone have a link to the video?
And do we remove the bolt completely or what?
I wouldn't mind doing this until I decide on what exhaust to order, just don't want to do anything wrong and mess up my OEM exhaust.
Old Aug 28, 2008 | 06:57 AM
Defratos's Avatar
You're Despicable
wait wait wait....what....how....when....&....where... Anyone willing to post a video up as I don't get what you guys mean, do you mean removing the exhaust completely? Cause that sounds wrong
Old Aug 28, 2008 | 10:20 AM
jerminator's Avatar
They're talking about removing only the mufflers. Not sure why someone would drive around like that as it just wouldn't look right. Also, I'd imagine you would be getting soot all under the rear of your car.
Old Aug 28, 2008 | 01:51 PM
g35_6gear's Avatar
The exhaust has a hanger at the rear that needs 2 bolts removed, 1 bolt on a hanger that can be accessed with an extension between the tire and the mudflap, and the last bolt is a clamp that holds the 2 flanges together underneath the spare tire well under the car. I took everything off without jacking up my car....and it is lowered. And unless you are burning oil, there would be no soot output onto the bottom of your car.
Old Aug 28, 2008 | 04:30 PM
Cali G's Avatar
Just FYI... I dyno'd my car w/ the OEM mufflers attached, then w/o any mufflers. There was no gain at all.
Video Share
Jan 31, 2017 04:00 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
Albanian122
Sep 12, 2015 04:02 PM
