Heavy clutch
Old Nov 4, 2008 | 09:33 AM
GJohn's Avatar
Heavy clutch
I've driven manual transmissions all my life, but my 07 sedan has the heaviest clutch I have ever experienced. This is actually causing me to have some pain in my left foot that deesn't want to go away. I have had the slave cylinder update, and even installed a custom made wider clutch pedal which helped a little. I hate to think I may have to sell my G over this. Does anyone know of any fixes or aftermarket clutches that can help with this problem? I've heard the 08 sedans and coupes have improved clutches, but does anyone know if this problem has been addressed?
Old Nov 5, 2008 | 07:34 AM
snowcrossmxz's Avatar
get some roids and juice up that leg of yours.
this makes me think your around 85 pounds..
im not sure what to tell you, i don't have any issues with the force needed to clutch my car. but then again im 6'2" 220 lbs
Old Nov 5, 2008 | 09:44 AM
jerminator's Avatar
Go sit in an 08 and see if the clutch pressure is less. If it is, then you should be able to change out to the newer components I guess.
Old Nov 5, 2008 | 10:02 AM
terrycs's Avatar
Heaviest clutch on the G? I've had a few domestic cars that were way heavier.
Could you be simply having foot problems? Ever consider an automatic?
Old Nov 5, 2008 | 10:13 AM
kool_yaar's Avatar
The clutch is heavier than what iv driven before but thats what makes it fun and after about a week of driving i didnt even notice it, just hang in there if you can and let it break in...
Old Nov 5, 2008 | 11:13 AM
Chris G35's Avatar
I actually find it quite light compared to my Acura I had. You must have knee problems.
Old Nov 5, 2008 | 04:02 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Part of the reason may be the length of travel in the pedal not just the weight.
After driving a BMW, I wasn't overjoyed by the pedal action on my '08 G35S.
After the pedal fix, I love the 6MT
Old Nov 5, 2008 | 07:48 PM
KulG35's Avatar
Integr8r hooked it up... going to so this DIY this weekend.
Old Nov 6, 2008 | 08:59 AM
GJohn's Avatar
That's very impressive, but I'm 6'3" and weigh 210. The problem is with my FOOT, not my leg. Maybe the droids go to your head.
Old Nov 6, 2008 | 09:44 AM
it is like a pressure point thing, the the peddle is too small and digs into ur foot?
Old Nov 7, 2008 | 09:05 AM
GJohn's Avatar
Yeah, I think that describes it better than I did. The wider clutch pedal helps some.
Old Nov 7, 2008 | 09:14 AM
where do u put the peddle on ur foot?
i drive bare foot a lot and i put the peddle right below my toes, like i can curl my toes over the top of the peddle and pull it back toward me if i wanted to.
so my pressure point is right in the center of the ball of my foot.
try wearing thicker shoes maybe?
Old Nov 9, 2008 | 09:11 AM
GJohn's Avatar
I'm trying thicker shoes now, and that is helping. I think I need to make sure the pedal is under the ball of my foot, and not pushing n my toes.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
AL8782
Oct 3, 2015 10:26 AM
Jpete
Sep 25, 2015 01:38 PM
bigmike
Sep 17, 2015 01:58 PM
