What are the cons of removing exhaust Heat shields?
Old 03-08-2009, 03:20 AM
Csquared's Avatar
Thanks for the reply, The heat shield i think is rattling is on the Y pipe so it's under the front and passenger seat. I'm looking into an aftermarket y pipe, but that has no shield on it either so i'm wondering if i'll still get the same problem as removing the heat shields. I'm not really looking for more power so I just don't want to spend 3-400 dollars and have the same cons, but a shiny pipe no one can see and like 2 whp more haha.
Old 03-09-2009, 09:00 PM
2GoRNot2G's Avatar
No problem, Clement.
Just try taking them off and see if it fixes your rattle... If so, then just leave them off... unless the cabin heat becomes unbarable, the have them reattached, but make sure they are more secure this time, so they won't rattle.
Old 03-09-2009, 09:09 PM
Csquared's Avatar
yeah I'm gonna try that i think, Now i need to find some ramps or something/
Old 03-09-2009, 09:13 PM
2GoRNot2G's Avatar
Just spend $20 and get yourself a set of jack stands and then use the factory jack to put the car up on stands.
http://www.harborfreight.com/cpi/cta...emnumber=38846
Old 03-09-2009, 09:39 PM
Csquared's Avatar
Hmm I'll look into that hopefully it'll give enough clearance, it's safe right? Those nuts on these clamps are crazy tight, I can drag myself across the floor trying to loosen them and they don't budge, and i'm heavy!!
Old 03-10-2009, 01:23 AM
2GoRNot2G's Avatar
Those are the same jack stands I use, so they should be plenty high enough, assuming your factory jack will lift the car up that high. If you can't get them loose, then try heating them up with a torch first... that usually does the trick... or you can also try a nut splitter to get them off, but you will ruin the nut in the process. Good luck, and let us know how it goes.
Old 03-10-2009, 03:04 AM
Csquared's Avatar
Thanks I'll try it out!!
Old 03-10-2009, 10:30 PM
Csquared's Avatar
I did it, I got a set of ramps and removed most of the heatshields, all the ones i removed were under the car and I kept the part that the Y pipe connects because that is right under underneath something that looks important hahaha.
IT WORKS NO MORE RATTLES!!
Old 03-11-2009, 12:16 AM
E-Ticket Ride's Avatar
Take a pic of what you removed so it'll help others with the same problem
Old 03-11-2009, 02:57 AM
2GoRNot2G's Avatar
WooHoo... Awesome!!! Glad to hear it, Clement. Post up some new sound clips when you get a chance, so we can all compare.
Old 03-11-2009, 02:59 AM
G35xQX1's Avatar
nice...nothing like pure unadulterated engine/ exhaust hum
Old 03-11-2009, 04:51 PM
Csquared's Avatar
Sorry, my bad took the car out and figured it's a lot better but there is still some resonance, I'm guessing it's either just they way the Air flows through the HFCs, or it's cause the Exhaust gases is slamming into the narrow 1.75 inch y pipe lol.
Old 03-11-2009, 07:02 PM
Time to get the rest of the mid pipes done
Old 03-11-2009, 07:42 PM
Csquared's Avatar
yes I guess, or it's just the HFCs making the noise, oh well I think my exhaust project is done for now, it's onto the exterior now, I'm waiting for that TK spoiler!!
And yes I think I've gotten used to the tanabes or something, I wish it was louder!!
skippyG
01-25-2016 01:18 PM
Shizzmaster2k
Engine - Exhaust
11
09-02-2015 04:09 PM
linedr89
08-17-2015 05:11 PM
CrazyLogic219
08-13-2015 06:40 PM
lemmy999
07-25-2015 12:13 PM
Quick Reply: What are the cons of removing exhaust Heat shields?
