STS TurboKit UPDATE!!!
#31
High compression motor and turbo are "a bad combination". Not to mention dual intake which make a little tricky to synchronize turbo spools. Utube clip sound like EWG dumping the air and boost is probably kept at spring rate much like MBC. Which in my opinion is another disaster if Ur G is a daily driver. Buy another car should you get a turbo charged engine!
Not sure what you mean by sync turbo spools ... this appears to the a single turbo setup for the HR which would be a first. There are a lot of questions I would be asking them if I were gonna do this. The first being if they really boosted an HR motor because they only posted the power curves from a DE motor.
Relaibility really depends on how heavy the drivers right foot is. When not on boost (most of the time), the stress should be comparable to a N/A motor. Being a daily driver should be no problem on a properly configured F/I system.
#33
#34
on
![BOUNCE](https://g35driver.com/forums/images/smilies/bounce.gif)
Since there are plenty of cars with this system I'm sure they have figured a way around it. Especially since it is tucked up underneath the car (even though I am no expert) I don't think the rain should be a problem as long as you're not submerging the unit in water.
#36
I don't think it has been done on an HR yet. Here are a bunch of DE's though:
1.) http://s229.photobucket.com/albums/e...ew¤t=Movie.flv
2.) http://www.ststurbo.com/sts_video
3.)
4.) http://videos.streetfire.net/search/...4e012b0039.htm
5.)
6.)
7.) http://s168.photobucket.com/albums/u...t=MVI_0642.flv
8.) http://s168.photobucket.com/albums/u...t=MVI_0643.flv
3.)
5.)
6.)
#38
#39
Simple just dont drive in the rain
#41
