Idle RPM drop??
Old Mar 6, 2011 | 11:51 PM
  #151
Neal376's Avatar
have any of you guys tried cleaning your maf's? I always found that cleaning that fixed more idle issues then anything else.
Old Mar 12, 2011 | 02:08 AM
  #152
dbodinof's Avatar
Well I finally got this fixed. Turns out my timing chain was off 1 tooth. Now she runs like a dream.
Old Mar 12, 2011 | 02:21 AM
  #153
kool_yaar's Avatar
^ glad to hear they figured it out, but how did that happen? was their some work done on to engine where they messed up? or do you suspect it was off from the factory? very strange.
Old Mar 12, 2011 | 02:54 AM
  #154
dbodinof's Avatar
Good question. So my water pump broke several weeks before. I suspect when it broke it may have interfeared with the chain. The dealership that fixed the waterpump was so shady they tried telling me I had bent valves and needed a new engine for 7k. Just FYI, don't ever go to nalley Infiniti of Decatur georgia. They'll slit your throat for a farthing.
Old Aug 28, 2012 | 03:51 AM
  #155
mmughal's Avatar
so do we have a solution for this finally?
I have a 2008 G35 Gulf Specs here in Dubai, this problem happened at 30k and now back at 95k
tomorrow reporting to dealer
Old Aug 28, 2012 | 08:02 AM
  #156
Q8y_drifter's Avatar
https://g35driver.com/forums/v36-diy...le-bodies.html
Old Oct 17, 2012 | 01:27 PM
  #157
Muzariazz's Avatar
My car starts, idles, sometimes even dies on me but if i give it a quick rev it starts right up, im gonna clean the throttle body either today or tommorow but before that i was wondering what are all the procedures i need to do before and after? espically the learning procedures?
Old Dec 26, 2013 | 10:47 PM
  #158
Kingcha58's Avatar
having the same problem on 04 coupe,have cleaned maf and tb, replaced maf and tb,new spark plugs, fuel injection flush, idle air relearn. am lost
Old Sep 5, 2019 | 05:01 PM
  #159
filya's Avatar
coupe base
no fix yet
my car has similar issue. while car is in D but stopped. RPM drop to ~500. thats when i get minor yet annoying vibrations. i cleaned TB, changed spark plugs, cleaned MAF and flashed ECU....stealership said it was engine mounts. local mechanic tested w/ computer and said idle rpm are normal. i have 100k miles. i end up driving w/ constant AC on now as it pushed rpm ~100rpm higher. which helps a lot.
Old Sep 6, 2019 | 03:02 PM
  #160
Eric@TCGMiami's Avatar
you may have to perform the idle air relearn.
DRG35R
Jan 31, 2016 07:14 AM
Rose M
Oct 12, 2015 10:00 AM
vamarris
Sep 26, 2015 12:56 PM
