Nissan Power Pup Bullydog - First Impressions
Old Jun 11, 2009 | 09:23 AM
  #496
08G35sDriver's Avatar
Originally Posted by AesonVirus
What's the stock redline shift point on our car?
I set my new shift point to 7700 RPMs but at WOT, it seems to be shifting sooner than it used to.
What are you guys setting your shift point to?
I think I read this somewhere along the way, that even though Bullydog allows the rev limiter to be raised, it doesnt change the shift points when driving in the regular D mode....or DS for that matter.
I think the only way to squeeze out the extra rpms is to do it in manual mode.
I havent tried yet really....Not enough runway for me anywhere.
Old Jun 11, 2009 | 11:14 AM
  #497
PursuitofG's Avatar
I believe it does change the shift points while driving in DS mode not sure about D mode.
has anyone increased the timing degrees higher than 2 degrees? any results?
Old Jun 11, 2009 | 12:30 PM
  #498
AesonVirus's Avatar
I'm not going above what the dealer's techs recommended (which was +2)
I believe the higher you go, the higher octane you will need in order to ensure proper detonation. Lower octanes will detonate too early and that causes a loss of power and knocking can also occur
I'm using 93 octane with my +2 setting
Old Jun 11, 2009 | 01:14 PM
  #499
jack090's Avatar
+2 is the maximum the BullyDog will let you do.
Old Jun 11, 2009 | 01:16 PM
  #500
BlackBerryCubed's Avatar
Since 91 is the highest octane available in california, is it advisable to up the timing to +2?
Old Jun 11, 2009 | 06:53 PM
  #501
bat6wc's Avatar
is there really that big of a difference between a bully dog tune with timing at 0 and a bully dog tune with timing at +2?
Old Jun 11, 2009 | 08:01 PM
  #502
Wes_888's Avatar
or the difference between just getting the timing adjusted at the dealership vs the cost benefit analysis of getting a bullydog for that matter.
Old Jun 12, 2009 | 08:36 AM
  #503
bmfgsxr's Avatar
my gut would say no, but id ask bullydog themselves.
Old Jun 12, 2009 | 06:11 PM
  #504
bat6wc's Avatar
alright, i set the timing to +2 this afternoon. Been driving around for a little bit now and im not sure I notice a difference.
Old Jun 12, 2009 | 06:36 PM
  #505
AesonVirus's Avatar
Hit the gas and get your RPMs up.
You should see a difference up there.
Old Jun 12, 2009 | 07:15 PM
  #506
bat6wc's Avatar
you're the boss...
Old Jun 12, 2009 | 07:16 PM
  #507
soundmike's Avatar
You have to go WOT or stay in the high revs to notice a +2 change in your timings.
Old Jun 12, 2009 | 07:51 PM
  #508
alti35's Avatar
I installed mine today and adjusted the rev limiter, speed governor, etc and added the premium tune. The only thing was that it says that I can't modify the timing or idle settings because the engine needs to reach 180 to 201 degrees. I wrmed up the motor and nothing changed. Do I need another version??
Old Jun 12, 2009 | 07:55 PM
  #509
bat6wc's Avatar
mine said that today when i adjusted the timing. I just waiting until the car warmed up and revved the engine a little. got up to 180 easily.
Old Jun 12, 2009 | 08:38 PM
  #510
AesonVirus's Avatar
Mine did that as well.
I sat in the garage with the engine running and I just watched the screen until the temp hit 180.
I was then able to make those changes.
The BullyDog shows the current engine temp as it's running
