Nissan Power Pup Bullydog - First Impressions
Old Jun 26, 2009 | 07:25 PM
  #556
soundmike's Avatar
Guys, don't know if it helps or not, but if y'all send me all the builds, i can host them online.
Old Jun 26, 2009 | 07:57 PM
  #557
beezy619's Avatar
That would be sweet!!!
Old Jun 26, 2009 | 11:00 PM
  #558
G35Now!'s Avatar
Moderation-free
Originally Posted by alti35
I let the car warm up about 15 minutes and still nothing. I drove the cr around town, then tried it again and nothing. It seems that it can't read the temperature because the power pup maintains the temperature screen always at 0 degrees. I'm going to call Bullydog and see if I need to download another version. Anyways, the rest of the tune is fine and feels great. Its cool to watch the rpm limiter at 8K, haha.
You need the new SW version - that'll let you change timing.
Old Jun 26, 2009 | 11:07 PM
  #559
drgsaik's Avatar
Just got the BD 44590 and received/downloaded ver. 1.2.2 G. It does not work. Contacted BD and they are supposed to come up with a new version for my part #. I was told to call them if I don't hear from them in 1 week.
Old Jun 27, 2009 | 12:29 AM
  #560
AesonVirus's Avatar
Well, the wait sucks, but this is the correct and only way to do it.
Don't just throw any tune in and hope for the best.
Let Bullydog get your specific # from the ECU and let them tell you which version is for you.
I hated waiting almost 2 weeks for my tune, but the wait was SO worth it.
Old Jun 27, 2009 | 01:06 AM
  #561
drgsaik's Avatar
Hey AesonVirus, any ideas what are the differences between all these A-G releases?
Funny they've never got a request for my part # before.
I hope i won't have to wait 2 weeks!!!
Old Jun 27, 2009 | 08:44 AM
  #562
a6g35's Avatar
I thought the different versions were just adding ECU#s to the running list.
So Version G list would contain all version F ECU#s + a few new ones.
Old Jun 27, 2009 | 11:35 AM
  #563
AesonVirus's Avatar
Correct.
These are minor tweaks to allow the car to accept the tune.
There are no performance based differences between these versions
Old Jun 27, 2009 | 02:52 PM
  #564
G35Now!'s Avatar
Moderation-free
Crap, the blown engine posts are freaking me out - my #1 rule for the G is it has to start every time I push the button, even limited risk isn't worth it for a few additional HP. Went back to the standard tune, and just stuck with +2 timing (plus removing the speed limiter, and keeping the 7,800 rpm redline )
I know it's a really small sample that have had problems, am probably being overcautious.
Old Jun 27, 2009 | 04:42 PM
  #565
InTgr8r's Avatar
Staff ALUMNI (retired)
^ has me wondering a bit as well.
That last one had other issues pre-BD.
Looking around the www I haven't come across anything bad about BD though.
Mainly software, same as here.
Old Jun 29, 2009 | 02:51 PM
  #566
BlackBerryCubed's Avatar
G35now: how do you go back to stock yet leave the speed limiter off ? I went stock today, and after that the only thing I could change was Timing I believe. I want it to be completely stock + 2 degree advance timing + speed limiter removed. I have the first 2 accomplished.
Thanks!
Old Jun 29, 2009 | 03:53 PM
  #567
a6g35's Avatar
Going completely back to stock means you reset ALL 3: 1. the fuel-specific tune 2. rev limiter 3. speed limiter.
Degree timing and idle timing are separate options.
If you want to be stock, but without speed limiter, re-run BD PP and leave item #1 @ the standard tune, leave item #2 untouched and change item #3 to something too fast... so its basically like stock, but without speed limiter.
Old Jun 29, 2009 | 04:41 PM
  #568
thanks for the info! I guess I will leave it at full stock just with the idel timings at 2. Going to return BD.
Thanks!
Old Jun 29, 2009 | 07:11 PM
  #569
kendroz's Avatar
Who can send me the latest 1.2.2 version ?
Old Jun 29, 2009 | 07:48 PM
  #570
G35Now!'s Avatar
Moderation-free
Thanks!
Hmmm, trying to remember. When I hooked up the BD, it went through the usual startup sequence, and I chose Settings or Options (whatever the top menu choice is - think it's Options). Then it took me through the sequence of 'choose your tune', click Y to edit speed limiter etc. So right now mine is stock tune + speed limiter at 168 (optimistic ), and rev limiter at 7,800.
P.S. It's great that the speed limiter's gone - I don't expect to ever get anywhere near max speed...but now I could...
