need a solution to this CEL problem.
Old May 20, 2009 | 09:47 PM
suby01's Avatar
Originally Posted by Lucky_One
so i have a CEL. Im pretty sure its coming from my Berks HFC. I had it on for little over a year, and then it suddenly came on couple months back. here is my theory on the problem.
I took it to autozone, got codes P0420 and P0430. these codes mean the rear oxygen sensors( the one on the HFC) are reading the exhaust air similiar to the air before the HFC(the ones on the headers i think). Converters are suppose to "clean the air" and provide different wave lengths between the two O2 sensors. i checked the headers, intakes, exhaust, and found no leaks or anything abnormal. what can i do to get rid of the light?
what im thinking of doing:
either buying new oxygen sensors for the rear or do a ecu tune. will either of these work to get rid of the CEL.
which, specifically, ecu tune would help the most----the bully dog, technosquare reflash, cobb, etc. thanks
https://g35driver.com/forums/tech-v3...ml#post4239855
Old May 20, 2009 | 10:13 PM
Lucky_One's Avatar
oh i get it now. ill apple the wool first and if that doesnt work, then ill try this method out. thanks suby.
here is a ?: it says to disconnect the negative terminal, which i assume to reset the codes etc. I always thought it was the positive terminal? or it doesnt matter which one?
Old May 23, 2009 | 08:51 PM
familyman333's Avatar
Does this fix apply to the forward or rear O2 sensor?
Old May 24, 2009 | 01:29 PM
Lucky_One's Avatar
the two extenders will apply to the rear o2 sensors. i dont believe it applies to the front.
Old May 24, 2009 | 04:32 PM
suby01's Avatar
the ones that you changed. no need to change the stock setup.
Old May 26, 2009 | 04:10 AM
kendroz's Avatar
I have the same situation, got codes P0420 and P0430 and i reset them with the bully dog. I been using FI HFCs for some time now and mine has the antifoulers. That started to happen after the bullydog reflash. Also when I pressed the start button and the car is cold, it stops and need to press the button again with the gas pedal on it.
Old May 26, 2009 | 08:09 AM
Defratos's Avatar
You're Despicable
^ so you got the CEL problem after reflashing with the bullydog? how long before that did you have your HFCs on for?
Old May 26, 2009 | 11:29 PM
kendroz's Avatar
A couple of months only.
Old May 27, 2009 | 12:44 PM
pwebb's Avatar
ALWAYS disconnect the negative first, and reconnect it last.
reason being - you ever notice the little spark that occurs when removing cables? if you remove the positive first , that voltage will have to travel through sensitive electrical components in order to find its ground. possibly frying everything in its path.
if this is done on the ground side, no damage to electronics will occur.
Old May 27, 2009 | 04:56 PM
Lucky_One's Avatar
several times now that i have taken the positive cable out and never had a spark on my once, even putting the cable back on, there was no spark. ill have to try removing the negative side. thanks.
06g35
Feb 14, 2022 05:59 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
AL8782
Oct 3, 2015 10:26 AM
TurTLe*
Sep 29, 2015 01:43 PM
