Anyone interested in working with OPENECU group to develop G35 compatible version?
Little more searching (didn't take much at all...)
And here's the datasheet for the processor. Instruction set and all: http://pdf1.alldatasheet.com/datashe...D64F7055S.html
I'm not fantastic at low-level assembly/disassembly, but someone that is should have a heyday with this and the ROM dump.
Help please identify the elements!
Hello!
Sorry that animate the subject.
But do not tell anyone component values. I had to pay, but already there places without indicated in the figure. As long as found by the photo from the Internet that:
1. R = 10 kOhm (mark 103)
2. R = ??? (mark ???)
3. C = ???
4. C = ???
Maybe someone has a fragment of the scheme or access to the unit.
In advance thank you very much, I hope you can help !!!
3. C = ???
4. C = ???
So, a little more info from this thread: https://g35driver.com/forums/tuner-d...technical.html
I have a newer ECU in hopes that I'll be able to go from the older "Maxima style" grey connector ecu to the newer black connector ecu.
I took apart the ECU to get ANY information that might possibly help out:
The info off the ECU is as follows:
It's from a 04 G35Sedan with AT
Outside label on the ECU reads:
Nissan
Hitachi, Ltc. Tokyo Japan
WA
MEC31-980 B1 3141
There's a QR code printed on the label that contains this information:
WAMEC31-980B10000WA341423710 AC0100155 (thank's QRDriod )
If you notice, the bold part is the "ECU number" that you can lookup on infiniti-techinfo.com except this particular one isn't in there for some reason
Inside the ECU, printed on the circuit board is:
31-980 in gold letters,
ge223471-a in white letters.
The chips, from left to right, top to bottom are labeled:
Motorola
mc38186dh
kkcz0246
l9302 - ad
b995c0312
l9302 - ad
b995c0312
789101a
a03(a1)
0310k323
The big one in the middle:
64f7055f40
rl 0306
bb02800
Then the last one:
l9762 - bc
b99140303
Hope this does some good
Nissan
WA
MEC31-980 B1 3141
Motorola
mc38186dh
kkcz0246
l9302 - ad
b995c0312
l9302 - ad
b995c0312
789101a
a03(a1)
0310k323
64f7055f40
rl 0306
bb02800
Then the last one:
l9762 - bc
b99140303
Looks like there has been a little progress with this over the years...
http://forums.openecu.org/viewtopic.php?f=15&t=2639
http://forums.openecu.org/viewtopic.php?f=5&t=5816
http://www.romraider.com/forum/viewt...hp?f=7&t=10897
http://www.romraider.com/forum/viewtopic.php?f=8&t=9888
http://ecuhacking.activeboard.com/t5...cu-reflashing/
I haven't read completely through all of those threads, some are a little over my head.
Qwertin (02-01-2016)
Thank you!
There about programs, instead of hardware.
I will look further!
poktanG35
Engine - Exhaust
10-26-2015 03:32 AM
