hi guys...i need urgent help...i installed fujita short ram intakes today and have driven around 100kms...my average till yesterday was from 11L/100km to 15L/100km depends on driving, but on average driving it was 11 to 12.
After installation it shooted up to 16 and sometimes 19 but average after driving for 100km came to 17L/100km and I was driving as my normal driving.
I need to know if there anything i need to know, as the kit is slightly used bought of this forum and looks clean so nothing wrong there, does everyone has this problem that car starts drinking gas after intakes??
I found a thread here for resetting the ECU and tried that not sure if it was done or not as instead of check engine light service due light was blinking in that.
any signs which shows that ECU is reset??
Don't worry about it man, just drive around and eventually your ECU will adjust to the change in A/F ratio. Give it a couple hundred kms and you'll be fine.
Thanks man...as I said I tried to reset it but not sure if it was done or not..anyways driving to Dubai tomo from alain and back ..hopefully it will get better
