changing Diff Fluid
Old Dec 14, 2009 | 05:57 PM
Austin713's Avatar
changing Diff Fluid
Hey guys, i found a bunch of stuff on the 1st gen sedan guys and coupes but nothing on our models. does anyone have a how to on changing the Diff fluid on an 07 Sport G35 Sedan? what fluid and how much to use?? any pointers?? dealer wants 100 bux
Old Dec 14, 2009 | 06:11 PM
CalsonicVQ's Avatar
It's so easy. 1) Undo the drain plug 2) Drain old fluid 3) Screw on drain plug 4) Undo fill plug 5) add new fluid until it reaches the bottom of the fill hole 6) Screw on fill plug. Remember to get new washers for the plugs from your dealer. The recommended tightening torque for each plug is 26 ft-lbs. Use GL-5 80W90 gear oil (I used AMSOIL 80W90 gear oil).
This should cost you $15-$20 if you DIY.
Old Dec 14, 2009 | 07:50 PM
james0076ss's Avatar
http://myg37.com/forums/d-i-y-instal...-gear-oil.html
Old Dec 14, 2009 | 10:17 PM
geronimomoe's Avatar
I'd recommend loosening the fill plug first. Would not be a good thing if you were not able to loosen the fill plug AFTER draining the differential ..
Old Dec 15, 2009 | 12:02 AM
CalsonicVQ's Avatar
Good point.
Old Dec 15, 2009 | 10:56 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
The procedure is exactly the same as 1st gen.
Old Dec 15, 2009 | 05:50 PM
Austin713's Avatar
thanks for the input guys. i just dropped my car off this morning to get the trans service done. only 179.99 and they drop the pan and change the internal filter. i asked about coolant and diff fluid and the service manager told me that from what they have seen you dont need to worry about either of those until 60k. dealer is West houston Infiniti. i give them props for not trying to screw me over. Southwest infiniti wanted 299.99 for the transmission service!!!
Eomfd
Aug 29, 2015 12:42 AM
All G'd Up
Aug 29, 2015 12:40 AM
jbmw002
Drivetrain
Aug 27, 2015 03:01 PM
NemesisGee
Aug 11, 2015 07:10 PM
myGspot
Drivetrain
Aug 11, 2015 11:58 AM
