Injen Intake
Old Feb 2, 2010 | 07:24 PM
Rutland's Avatar
Injen Intake
http://www.injenairintakes.com/
Item# SP1997
Yes, I did a search and about 400 posts came up. So, I figured I'll just ask here.
Do you need the hydroshield and what's the difference in filters: oil or dry?
Thanks to those who respond.
Old Feb 2, 2010 | 07:53 PM
soundmike's Avatar
I personally think the hydro shield is just a gimmick. By the time you submerge both filter elements in water completely, you've probably already hydro locked the engine at that point, shield or no shield. Although, i can't recall where i found the video, it takes quite a bit of effort for your engine to actually suck water through that long tube, through the filters.
As for oiled vs. dry, usually dry filters can filter better than oiled (K&N) but will need to be replaced more often. I've had K&N before, but other than the million-mile guarantee, i really don't see any sense in paying for, or using it over dry filters.
Old Feb 2, 2010 | 10:51 PM
AesonVirus's Avatar
The hydroshield covers protect from splashes and winter time grit and grime.
They won't protect you from heavy soaking.
Old Feb 3, 2010 | 01:50 AM
J2S2M's Avatar
Anybody try these hydroshields? I actually was considering these for my STILLEN Gen 3 intake. Just not sure if they are worth it..
Old Feb 3, 2010 | 03:52 AM
PhantomCoupe's Avatar
eh shouldn't really need it.
just dont drown your poor g
Old Feb 3, 2010 | 07:38 AM
AesonVirus's Avatar
They also help to keep the oil based filters clean, adding time between necessary cleaning.
I read a study somewhere once that showed that they reduced air flow slightly.
In NE winters, I'd probably use them on oil based filters. I haven't bothered adding them to my dry filter setup though. My filters are still pretty clean.
Old Feb 3, 2010 | 08:49 AM
Rutland's Avatar
Thanks for all the information guys (and sorry if I posted in the wrong forum).
bookmarking this page
Picture Share
Feb 4, 2018 12:41 PM
Video Share
Jan 31, 2017 04:00 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
vamarris
Sep 26, 2015 12:56 PM
