Transgo valvebody upgrade kit
Old Mar 20, 2010 | 09:04 PM
Pennywise1971's Avatar
Has anybody done the 5sp automatic transmission TRANSGO VALVEBODY UPGRADE KIT RE5R05A-HD2 on their own? How difficult is the valvebody upgrade? Do you have any pics of the process, or hints that make it easier? How does the transmission react after the upgrade, casual driving and stomping on it? How much WHP can the trans handle after the upgrade?
Old Mar 20, 2010 | 09:07 PM
elayman's Avatar
a couple of threads about this already.. use the search feature
Here's a DIY (I'm attempting this next week)
https://g35driver.com/forums/engine-...y-upgrade.html
Old Mar 21, 2010 | 06:57 AM
Q8y_drifter's Avatar
I'm gonna do this at some point in time. I'm probably gonna go with the GTM Valve Body kit which includes a new valve body core, upgraded with the Transgo kit as well as their own upgraded/modified solenoids.
Old Mar 21, 2010 | 08:54 AM
I think GTM has to use your valvebody because they are VIN# match to your ECU. Has anybody actually talked to GTM to findout if they really do put upgraded solenoids in the valvebody?
Old Mar 21, 2010 | 09:42 AM
If GTM does upgrade the solenoids, how much more WHP will the trans handle before the clutches start slipping. I have heard the 5AT with the valvebody upgrade and trans cooler will hold up to 500whp.
Old Mar 21, 2010 | 10:42 AM
elayman's Avatar
^ I don't think it's a whole lot more. I think they have a whole valvebody replacement for big hp gains, but it's expensive
Old Mar 21, 2010 | 04:51 PM
G35s-Q8's Avatar
I've ordered mine with their Racing trans. oil cooler kit, i hope it's a simple swap business.
Old Mar 22, 2010 | 12:37 AM
Lucky! Man you gotta tell me when you go to install it I wanna see.
Old Mar 22, 2010 | 05:46 AM
IvoryPearl07G's Avatar
those that run trans cooler kits, do you keep the trans fluid routed through the radiator, or do you just use the radiator connections and eliminate the radiator routing?
Old Mar 22, 2010 | 06:12 AM
GCC spec cars have a stock trans oil cooler from factory. I'm not sure where it routes though. G35s-Q8 you have any idea?
Here's a few pics>
Old Mar 22, 2010 | 03:16 PM
4drsleeper's Avatar
Looks like a great mod, I'd love to have it. Let us know how it goes.
Old Mar 22, 2010 | 04:34 PM
G35s-Q8's Avatar
Don't worry, you'll be the 1st one i'd call, i need you to document everything and take pictures, also you'll get to drive the car and test it so that you can write a review, your reviews are very detailed and nice, unlike me, i'm too lazy to write anything .
Originally Posted by IvoryPearl07G
Those that run trans cooler kits, do you keep the trans fluid routed through the radiator, or do you just use the radiator connections and eliminate the radiator routing?
Some of my friends leave it go thru the radiator, some of them don't, everyone got their own idea's, and i doubt if there's any difference, maybe 1 degree up or down.
The lines come from the transmission to the cooler, and then it goes back to the transmission, i'll swap our stock (10" x4.5" x 1") cooler, with a massive (16" X 7.60" X 2" 25 Row 22mm) racing oil cooler, because temperature here in Kuwait get's to more than 122 day time, and maybe 110f at night, it's hot like hell here.
jsimonk
Dec 22, 2023 03:49 PM
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
G35VSHNG37
Oct 25, 2015 08:43 PM
MooseLucifer
Sep 1, 2015 05:11 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
