5AT cruising revs
Old May 10, 2010 | 04:25 PM
G-Man.usa's Avatar
5AT cruising revs
Took my G on the freeway for the first time yesterday and was irritated to see the revs holding around 3200prm for speeds of 75/80 mph.
Is this normal? Seems very high compared with my Z which was very quiet in 6th in terms of engine revs and noise at the same speed. The G is more like the piece of crap MT Impreza my wife had with a very short top gear.
Old May 10, 2010 | 04:35 PM
erklep's Avatar
yep its normal. you can look into swapping rear diff out or just changing gears. but thats about normal rpm for that speed with the 5AT
Old May 10, 2010 | 04:42 PM
bigc's Avatar
Wings Nation
3200 is a tad bit high, but is probably within the margin of error of the OEM tach. I've noticed a decent amount of variance between the tach and my PLX gauge which pulls data from the OBDII port.
What year is your G and does it have the 3.3 gears? I know a few folks with 3.5 gears that cruise around 3200.
Old May 10, 2010 | 05:08 PM
Q8y_drifter's Avatar
3200 sounds about right. If you want a lower RPM then swap out the 5AT for a 7AT from the junkyard.
Old May 10, 2010 | 05:23 PM
G-Man.usa's Avatar
*Groan*
Ah well, I'll just have to live with it I guess. It's an 07 G35x and I'm still wondering if trading my 350Z roadster GT was worth it...
Old May 25, 2010 | 12:48 PM
Hardly Matters's Avatar
When I first got my 08 G a couple of weeks ago, I thought my car wasn't switching from 4th to 5th on the highway since it was revving so high. My Jag was about a thousand rpm less at 70 mph. When I switched to manual mode and it showed I was in 5th gear, I realized that Infiniti takes the HR (high rev) letters they place after the engine number seriously. I get 25.4 mpg on the highway though so it's fine with me.
Old May 25, 2010 | 12:54 PM
G-Man.usa's Avatar
^ That's pretty good - I'm getting about 24 highway @ 5000ft.
Has anyone done that 7AT swap? Is it from an earlier Infinity?
Old May 25, 2010 | 01:15 PM
the 7AT is used on the 09+ G's and other Infinitis and Nissans. I don't know what it takes for a full swap but it should be easier and cheaper than an auto to manual swap.
Old May 25, 2010 | 03:27 PM
terrycs's Avatar
You should still be getting 17-18 MPG combined or better unless you are driving like a maniac.
Old May 31, 2010 | 04:26 AM
docaam's Avatar
on 7sp it drops from 3200 to 2800
magnetism80
Feb 1, 2019 10:00 AM
mbe32
Nov 13, 2015 11:09 PM
heynow
2nd Gen (V36) Sedan
Oct 28, 2015 05:09 PM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
vamarris
Sep 26, 2015 12:56 PM
