Injen SP1997 Cold Air Intake for 07 G35 Sedan
I am thinking pretty seriously about buying and installing an Injen SP1997 cold air intake for my 07 G35 Sedan and am wondering if anyone has installed one already. If so, are there noticeable improvements? Any other recommendations will be appreciated as well.
Thanks,
$cott
Thanks,
$cott
Injen SP1997 cold air intake for 07 G35 Sedan
Based on some of the responses to this thread as well as other postings in the forum, it seems that stock air cleaner intakes are better than the Injen SP1997 for performance. If I install the Injen Cold Air, will it decrease performance?
Thanks for all of the help so far,
$cott
$cott
I would recommend doing some more reading and searching. I have purchased a cold air intake for almost every car I've ever owned but after reading reviews on this site I have made the decision to save the money. From what I have gathered, the stock design is engineered very well and aftermarket intakes alone will not yield much gain. On the othear hand it depends on how far you are going to go with your G; if you did Intake, HFCs, and exhaust with a tuner then it would be worth it. For basic every day drivers or simple bolt-ons I would not bother with the intake....my .02
If your looking for gains it's not much to begin with. On the other threads here, some people have lost horsepower with certain intakes. However it all differs on every car. I have Fujita SRI's on my car and people claim that it loses power.
Intakes on G's are generally just for sound and looks as i said earlier.
I just installed these on my 07 G35. Do I need to flash the ECU? If so is it the standard remove the negative and hold the brake pedal 10 sec?
but makes my car run rich as hell I think
anyways, running rich cud lead to a serious problem, your pistons may break !
you should tune ur car or you may go back to stock. ( BTW . . running rich is a good sign tho, u wud get nice gain after tune )
