2005 atx to 2007 atx vqde35 tranny swap (tcm reprogram)
Old Nov 7, 2017 | 05:08 PM
quickspeed6's Avatar
I want to know if i put an ATX from any newer year VQDE35 into my 2005 ATX g35 will i need to have the TCM reprogramed. Hell if you put any tranny in there from any year will the TCM need to be reprogrammed? Or can i just install tranny / tcm and go? i know if i were to get a NEW valve body/ TCM that i will need it to be though.
Old Feb 10, 2020 | 02:30 PM
Anyone? cars been sitting and i am about to get it ready to give to my son for his 18 birthday in a few weeks..
Old Feb 10, 2020 | 05:13 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Unfortunately it's pretty hit/miss when it comes to transmission swaps, however, the 2007 X models were only available mated to the HR motor and that will not bolt up to your DE engine without swapping bellhousings, since that TCM was designed to communicate with an entirely different ECM it's a fair bet it won't won't without programming.
The RE5R05A was bolted to pretty much every Nissan vehicle with different bellhousings, Titan, Pathfinder, Xterra, G35, 350Z, M35, FX35, M45, G37, and a couple of Kia applications. I think this is where a lot of the "TCM needs reprogrammed" issues come from, because people are pulling them from other vehicles that are NOT a matching chassis G35.
If you pulled a 2004.5 - 2006 G35 it will PROBABLY work without programming. I'm not aware of anyone doing transmission swaps from a known donor vehicle that had the correct chassis who needed the TCM reprogrammed.
You could always take the TCM from your existing vehicle and put it in the donor transmission.
Old Feb 10, 2020 | 05:16 PM
cleric670's Avatar
BANNED!!!
I just noticed you posted in the V36 sub forum, if your vehicle is a 2007 then you will want a transmission from another X sedan 2007-2008. You could swap your existing transfer case in place of the tailshaft housing of a non-X model without any other parts besides a gasket I think.
Old Feb 10, 2020 | 06:08 PM
scumbagsleeper's Avatar
1990 Mustang GT - 351W Lightning bored/stroked 383CI TFS heads 78mm Turbonetics huricane
Pretty much what cleric said. The HR trans I believe has different internals and may have a different front pump so I'm not sure about swapping 07'-08 x' bellhouse and TQ converter to a 03'-06' x. It might work but that is the one combination I haven't tried yet. If you do try it make sure the spline count is right and measure the TQ converter spacing from bellhouse after swapping. And don't try swapping pumps if the spline count is different.
Old Sep 1, 2024 | 07:45 PM
Kaza96's Avatar
G35x Awd sedan Grey
. I currently am in a situation where I swapped my 04 g35x sedan trans with another automatic from the same year. Infiniti says my year shouldn’t need programming, Infiniti says they can’t reprogram the trans. I still have my old TCM and Valve body.. do you think putting them in my donor trans will work?
quickspeed6
Drivetrain
Feb 10, 2020 06:13 PM
quickspeed6
Drivetrain
Dec 27, 2018 03:17 PM
n2okpride
Jan 14, 2010 02:25 PM
Mr_pharmD
Archived Sales
11
Apr 7, 2009 11:22 AM
deepakhj
Oct 9, 2008 03:16 PM
