check engine light: code P1065
Old May 3, 2007 | 07:21 PM
vietster's Avatar
so my check engine light is on, went and got the code pulled and it's the
ECM power supply heater(P1065). anyone know how to fix this problem or do i have to take it to the dealer to fix. i dunno even where to start with this problem. any ideas???
Old May 3, 2007 | 09:39 PM
vietster's Avatar
okay i found the steps to manually clear the code. hopefully this will fix the problem. here is the instructions if anyone needs it(got the info from infinityhelp.com).
- Manual Method
Here is a quick way to reset your ECU. It is also known to clear codes thrown, and turn off the "Service Engine Soon" Light.
Confirm that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
Repeat the following two procedures quickly five times within 5 seconds:
Fully depress the accelerator pedal (HARD).
Fully release the accelerator pedal.
Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the CEL starts blinking.
Fully release the accelerator pedal (while the CEL is still blinking)
Wait about 10 seconds.
Fully depress the accelerator pedal and keep it for more than 10 seconds.
Fully release the accelerator pedal (The CEL light will continue to blink).
Turn ignition switch to “OFF” position and now you can start the car. The CEL light should be gone.
Old Jul 10, 2014 | 08:28 PM
imRACERX's Avatar
P1065 ECM Power Supply Heater (code on reader)
Hey guys im having the same code. anyone know which relay i need to replace on the IPDM? i would hate to replace the whole module. anyone got the fix for this code? please and thanks. John
Muski_G
Dec 1, 2023 11:11 AM
ara777
Aug 15, 2018 04:11 AM
Kng0fHrts
Sep 15, 2015 05:40 PM
ClwMike
Jul 23, 2015 12:55 PM
Jadenkid22
Jul 14, 2015 12:33 AM
