fog light hacking
Old Jun 4, 2007 | 10:15 AM
HungNg85's Avatar
fog light hacking
For US version we cannot turn on fog light without turning on the headlight. Any G35 guru here knows how to hack this?
Old Jun 4, 2007 | 10:23 AM
Hi-TechG35's Avatar
KP technologies makes a module to control the fog lights seperately. Here's the link http://www.kptechnologies.com/
Old Jun 4, 2007 | 11:29 AM
HungNg85's Avatar
Nope, their product works on coupe only. I am talking about 07 sedan.
Old Jun 4, 2007 | 11:40 AM
Hi-TechG35's Avatar
Sorry...I tried...lol
Old Jun 4, 2007 | 12:08 PM
viguera's Avatar
Ask him... he might do it. He works on the coupe stuff first because that's what he owns, so with the service manual and a test car he might be able to work something out.
Old Jun 4, 2007 | 12:13 PM
Hi-TechG35's Avatar
^+1 agreed
perry05G35's Avatar
I don't see the point of this modd since the G35 fogs are all in the headlight assembly if they were seperate then I could see a demand for this modd.
Old Jun 4, 2007 | 12:28 PM
G-Whizzer's Avatar
I think they're looking for daytime running lights....
Old Jun 4, 2007 | 12:46 PM
logik05se's Avatar
wire them to your parking lights....did this on my coupe worked fine.
Old Jun 4, 2007 | 01:48 PM
Altersys's Avatar
you don't need a "G guru" for this....
just rewire the relay that controls power to the fog switch to take signal from IGN instead of the headlight line.
that said, it is illegal to run fogs without heads.......
Old Jun 4, 2007 | 03:01 PM
HungNg85's Avatar
Well, I don't think I want it that way.
I want to use the stock switch to turn on the fog light and that is why I need help from Guru
Are you sure it is illegal since the grand cherokee turns on fog independently (2006)
Old Jun 4, 2007 | 03:04 PM
redlude97's Avatar
its not that easy since the G uses alot of common wires to power the headlights, you won't be able to use the stock switch by just rewiring
Old Jun 4, 2007 | 04:13 PM
Altersys's Avatar
that's what i'm describing.
Old Jun 4, 2007 | 06:48 PM
johnmax's Avatar
KP was looking into building a module for this on our FXs. Might want to pm him and see if he can look into it for the G sedan.
Old Jun 10, 2007 | 08:00 PM
KPierson's Avatar
TTrank is testing a sedan version of the KPtechnologies fog light module, but hasn't had any luck with it yet.
