Install New replacment Cabin Filter,
Old Sep 28, 2007 | 11:14 PM
hrp783's Avatar
Exclamation Install New replacment Cabin Filter,
has anyone replaced the cabin filters in our car? or have spec sheets on how to? i know someone has the files that has the infiniti manual that shows you how to get to it replace it.
thanks guys.
Old Oct 7, 2007 | 09:30 PM
st1sj's Avatar
anyone answered you? i imagine the filter is located behind the glove compartment. hope it's not too difficult and possible for DIY.
Old Oct 8, 2007 | 10:18 AM
Ripple's Avatar
Can I ask why you want to replace it? Is it due to a sour smell?
I ask because I have had an issue recently with the car really smelling terrible when first starting and I suspect it is due to a bad filter.
Thanks.
Old Oct 8, 2007 | 10:59 AM
hrp783's Avatar
ya its the smell, mfgr suggests to replace the cabin filter every 15000 miles, on everything35.com you can buy the filter and do it your self, i took apart the glovebox and found it and can be replaced on our own, but its a hassle that i dont want to do... but you can take apart the glove box and it sits in a white filter box. the hardest part is to put the glove box back together.. thats y i dont want to do it again, i dont want to break anything i rather have the dealership do it and im sure there is an easier way to do so but i dont know how...
as far as the smell, run the a/c on fresh air more then recirculate
Old Oct 19, 2007 | 08:52 PM
AesonVirus's Avatar
Actually, it's condesation left in the system when the car is shut off causing the mildew.
Changing the cabin filter will do little to resolve the problem.
About 5 minutes before getting to your destination, hit the A/C button, turning it off.
Allow the fan to continue to run, which will dry the system out so when the car is shut off, moisture is not left there to turn all nasty in the condensor coil.
Easy habit to start, and the horrible moldy A/C smell will never haunt you again.
Old Oct 20, 2007 | 03:43 AM
Fassster10's Avatar
man this do it yourself job its cake, like 5-10 mins tops, plus you save like $60dollars, search for the DYI
Old Oct 20, 2007 | 06:30 PM
stinky's Avatar
I used to treat mildew by turning the car on AC and fresh, fan real low, and spraying a goodly amount of Lysol into the intake outside. Then turn off and let it sit overnight.
Old Oct 20, 2007 | 06:51 PM
Yv12345vY's Avatar
Did it this morning. It was really easy and quick! All you need is a philips screw driver.
Old Oct 24, 2007 | 02:50 PM
Okita240's Avatar
Where did you guys buy the filter? All my search only shows up the older G35 filters.
Old Oct 24, 2007 | 04:50 PM
st1sj's Avatar
where is the in cabin air filter located?
Old Oct 24, 2007 | 05:09 PM
Okita240's Avatar
It is behind the passenger glovebox
Old Oct 24, 2007 | 10:17 PM
B L U E S L A T E's Avatar
Honda Accord
How long did it take you? And did you have to remove the whole assembly?
Old Oct 24, 2007 | 10:50 PM
G35Now!'s Avatar
Moderation-free
You remove the lower part of the glove box - entire operation should take no more than 30 min even if you're being REALLY careful.
EPG35
Aug 16, 2015 04:52 PM
CJay
Aug 1, 2015 03:57 AM
ClwMike
Jul 23, 2015 12:55 PM
vstypicals
Jul 20, 2015 10:55 PM
justgotg35
Jul 19, 2015 12:33 PM
