Whats The Trick to Removing Push Rivets?
Old Nov 9, 2007 | 07:04 AM
XR400R's Avatar
I changed the oil on my '07 G35 for the first time last weekend, & in removing the plastic underpan, I managed to destroy two of the three plastic push rivets in center of pan in using a screw driver to remove. And I've noticed the same type of rivets are used all over the car to retain various plastic panels (notice in battery compartment).
Can someone advise me as to the proper technique for removing them without damaging them so badly they are not reliable for reuse? Is there a special tool (they are extremely difficult to get to in some locations)?
Thanks for any advice.
Old Nov 9, 2007 | 07:57 AM
G35Now!'s Avatar
Moderation-free
I just gently use a flat-head screwdriver, and pry them out from one side, then finish on the other. That pops it out enough to remove - to remove the pin completely for reinsertion, I use pliers with one jaw on the base, and the other on the point of the pin. Squeeze gently, and they pop out. Haven't broken one in a long time.
To put them back, squeeze the open prongs back together for a sec, put the base (with prongs) in, then the pin.
Old Nov 9, 2007 | 08:31 AM
XR400R's Avatar
Thanks for the tips! I'll give that a try next time.
Old Nov 9, 2007 | 10:32 AM
IvoryPearl07G's Avatar
i work at nissan in smyrna tn.... those pins are great to use in a production setting when fresh out of a bag....nice and smooth, sliding gently and smoothly into their intended locations.
its amazing how much they harden up and become fragile after a year or so. I have found they will break if they wanna break. Try to do as G35Now! said and do one side at a time going a millimeter on each side. the 2-4 mm you get is enough to pull it out. if you get the pin slid up some, you can pull on the panel itself(the one its holding) and it will pop out even easier.
we do have tools that are called a "crows foot". its got a screw driver style handle and the metal prong that comes of the end has and anged edge in the shape of a V. it allows you to slide it under the pin head and around the shaft....then all you do is pry it up....finally slide it under the base and pry the whole pin out. they should have those in a parts store or a tool providers catalog.
Old Nov 9, 2007 | 11:37 AM
XR400R's Avatar
^ Outstanding! Even more good tips. Many thanks.
Due to their commonality on the G, & my ham-handed mechanical abilities, I'm about to order a handfull of them from:
http://www.autobodytoolmart.com/p-10...-in-rivet.aspx
But I'm wondering if it wouldn't be simpler just to run a self-threading bolt into these locations, & forget the chintzy plastic push rivet? I know we're talking about very thin aluminum here so that might be difficult.
I'm wondering why Nissan did this in the first place? After securing this underpan with 5280 little 10mm bolts, why not three crummy more in the middle of the pan?
Old Nov 10, 2007 | 09:03 AM
lol cost savings man....save on putting a pocket nut there and save and the said 10mm bolts. thats a few cent's! add that to every bit of profit made to the model thusfar....
it adds up
Old Nov 10, 2007 | 08:28 PM
blnewt's Avatar
XR400R, not sure about the X, but our 07 Journey has a hinge on the engine undercover and you just have to remove the back 4 bolts and fold the cover back to expose the oil pan & filter.
Old Nov 12, 2007 | 04:27 PM
st1sj's Avatar
i just brought a "door upholstery remover" from sears for 8.99. sears also sells a set of removers.
Old Nov 12, 2007 | 04:34 PM
Adon's Avatar
hell with taking them out, I wanna know how the hell do you put them back IN!!
thats the hard part, cuz 1 or 2 of those 4 fins is always bent outta shape after taking it out and I have to use a tool to clamp them back together so they get stuck to the pin again and then just hammer it back in.... I hate those pins, it's like 50 year old technology and it seems they could have something a lot simpler and easier to operate
Old Nov 12, 2007 | 08:42 PM
blnewt's Avatar
Nice pic of your access door. Our Journey has a different setup, the entire width of the plastic undercover has an indent about 3/4 of the way back and you just remove the rear 4 bolts and bend the cover back to expose the entire oil pan & filter.
Old Nov 12, 2007 | 09:41 PM
ti_rider's Avatar
If you look at those rivets, you'll notice that the center pulls out. If you pop this center out (with a pick set or a screwdriver) it will let the outer wings collapse. After you do this, they will slide out easily.
To put them back in, just do the reverse. Pull the center out, put the rivet in, and then push the center in. I couldn't find a picture of the exact ones that I have, but these are pretty close.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Video Share
Jan 31, 2017 04:00 PM
dcsbh1
Oct 1, 2015 03:15 PM
