Safest place to jack up front for oil changes?
Old May 15, 2008 | 07:06 AM
alphamatt's Avatar
Originally Posted by Wei
yeah, my last car was 2 inch from the ground, no ramps would work, have to drive up staggered wood blocks/pieces just to drive on to make room for the floor jack
i don't think it should be too confusing to see which part of the frame can be used as a jack point, now i have to go and look, lol
haha i feel you on that, took me 45 minutes just avoiding cracking my sideskirts
Old May 22, 2008 | 06:08 PM
oughttoreturn's Avatar
Center Jack Point Found!!!
I finally figured it out! There is a center jack point on the G35. It's part of the crossmember or suspension. Just look between the two front wheels, there's a thick plate and at the bottom of it a protuding round *** or notch for the jack! I estimate the distance of the *** to tip of front bumper is 35 inches, this will help when deciding which jack to buy.
I tried ramps before but they are too scary....
Not going to take my car to dealer or shops anymore
_________
2008 G35 journey5at ivory/stone+prem&sportpkg(k&n airfilters)
Old May 22, 2008 | 10:01 PM
I just bought a floor jack, the low profile type for lower cars, man it dont work. The jack point is too deep which dont allow much movement of the pivot action..
****, I'm going to tryp rhino ramps or jack up the driver's side which someone mentioned earlier.
I think I will get a floor jack kit, saw a Torio big red jack kit for $35 at pepboys, a basic 2 ton jack, 2 floor jacks, and a creeper. Plan to jack one side up, put a jack stand, lower it and do the same for other side, not going to use center jack point... probably the underbrace which i guess is the round plate with dounut hole thingey part of the suspension... will get back hopefully I dont die-
Old May 29, 2008 | 05:05 PM
mrclowny's Avatar
umm u still alive?
Old May 29, 2008 | 09:49 PM
ez-g's Avatar
Originally Posted by geronimomoe
I build wooden ramps, bolted 2x12's together, for a 6" rise and also bolted 2x10's together, for a 6" rise.
Does well with our 06 Odyssey, all our previous cars, and my parent's cars.
I'm just a bit leery of Rhino ramps. They're plastic and if they fail, I don't think there will be any warning.
+1 I made mine from 2x8. Cheaper and probably safer than plastic or jacks. Stagger the cuts to get whatever drive up angle you want, whatever length you want. May want to nail an extra block on the front end so you dont drive off. Spray paint them whatever color you like to "pimp them out" or put a picture of this wacky guy there to scare little kids away from the work zone.
Old May 30, 2008 | 02:58 AM
Comatose's Avatar
Ok for those whose floor jackstands' grooves are too deep, what are you using to hold the car up after jacking it up?
Old Jun 5, 2008 | 02:22 PM
blnewt's Avatar
Just used my $8 ramps, worked great and are heavy enough that they don't move once in place. Just used (1) 4x8 sheet of 1/2" OSB cut in 8" wide strips (Minus the width of the saw blade, so about 7&7/8" wide).
Just cut the sheet in 12 equal 8"x48" strips then start your cuts at 12"/36",14/34,16/32,18/30,20/28,22/26~Do 2 of each size and you'll use all your 4x8 sheet and have enough pieces for two ramps. I used extra scrap for the pieces used for the wheel stops, you could also use a piece of angle iron or a trimmed down 2x4. The advantage to using this type ramp is the OSB is formed under massive hydraulic presses so the weight of a car or even large truck doesn't have any compression effect on the wood, so it's very stout
Old Jun 5, 2008 | 07:11 PM
07BlueOnyx's Avatar
I'm in the middle of swapping in some summer shoes and bought a floor jack to help. I have one back wheel done but I ended up "crimping" the lip a bit where the notch for the factory jack is supposed to go. Do you think the sub-frame located at the front half of the car is strong enough to do my front wheels? I'm not really sure where else to put the floor jack without further damaging the lip.
Edit - There's also a very solid looking metal bracket attached to each side of the sub-floor. Could this a spot for a floor jack?
Old Jun 6, 2008 | 08:35 AM
Gee3point5Mhmm's Avatar
i jack the two sides up. First i start off one sidde then lay a stand then the other and lay a stand there. eases my mind.
Old Jul 3, 2008 | 07:18 PM
G-perz's Avatar
Originally Posted by terrycs
I still haven't tried the ramps yet myself because I've been getting free changes at my dealer. Does it require two people? One to drive and the other to spot?
An old bathroom mirror is a good tool to watch you left front tire while boarding.
Never hurts to put a jack stand under for safety. I used to slide a cinder block under my car/truck b4 I had jack stands. I figured I was squishy enough that the block would keep me mostly safe.
Old Jul 3, 2008 | 07:50 PM
SVLRx's Avatar
li want to get the rhino ramps, but my driveway looks like this is flat for about 5 feet, then goes up at like 27 degrees.. half of my car would be on an inclie while the other half is on the flat ground
Old Jul 3, 2008 | 09:20 PM
Defratos's Avatar
You're Despicable
You know I've done the exact same thing to my audi, I've got a nasty bit behind the drivers seat where the ground has bugled up, and I'm sure it wasn't me who did it cause I'm "always" careful. Until today I still haven't gotten it fixed. Do you think this affects the handling in anyway?
Old Apr 13, 2009 | 09:13 PM
Alex D's Avatar
You can jack the front of the car up by using two floor jacks, each under the rocker panel jacking point for the oEM tiire change jack. There are two notches in the welded rocker panel seam where those jack points are. I always use a hockey puck as cushion and belive it or not the puck WILL NOT BE CUT by the sharp edge of the rocker panel seam. It actually conforms to the seam and provides safe support. Always secure the car with appropriate jack stands after lifting it!!!
Old Jun 17, 2009 | 01:43 PM
ampsucker's Avatar
cinder block very bad idea. many have been killed not realizing how easy it is for a vehicle to crush a cinder or cement block.
wood also somewhat dangerous. plywood or osb probably better then a big chunk of pine or oak as the big chunks can split on you and send the car down.
best to use a purpose built jack and set of stands or ramps that are rated for the load you will be lifting. you can get a set of jack stands for 25 bucks. not worth risking your life, if you ask me!
amp
DRG35R
Jul 31, 2015 10:23 AM
rping
Jul 26, 2015 09:53 PM
ClwMike
Jul 23, 2015 12:55 PM
