GTSpec Ladder Bar
Old 08-03-2008, 04:48 PM
ParkStr8's Avatar
Body Flex & GT-Spec Ladder Bar
Ok...after several searches I've only come up with a few threads that address the body flex. And like many others, I have it when backing out of my driveway or going up steep inclines at an angle.
I believe that this flex is what is causing the rear deck to rattle, sunroof rattles, and the front windshield to also move out of place (as in the other threads). It's only when doing a movement like this that i have the issues...and in LA, we have wierd hills everywhere and wicked parking entrances...and not wicked in a good way.
I've researched the GT Ladder bar...but has anyone installed it and to what effect? I have a three year lease, and rattles are not a part of my agenda. So if this is a fix, plus will upgrade the handling, then I'm all for it.
If it works...where did you get it and how much? The GT site they are 300. Easy install, or?
Thanks.
-s-
Old 08-03-2008, 08:36 PM
sredish's Avatar
can you post a link? I can't find anything for a ladder bar for our car.
If your talking about the strut tower brace, then there's some info on it here and they're currently on BO. I should have mine hopefully w/in 2 weeks.
Old 08-04-2008, 12:01 AM
kool_yaar's Avatar
^+1 i dont know of any other suspension bracing upgrade other than the front strut as far as we know, so if you have a link plz post. Thanks!
Old 08-04-2008, 12:06 AM
earth0's Avatar
Is this what you mean? from Tanabe.
http://www.tanabe-usa.com/other/files/222_img1.jpg
Under Brace 2 Points available for our 07-08 g35 sedan $98.00
http://www.tanabe-usa.com/underbrace/default.asp
Old 08-04-2008, 02:19 AM
ParkStr8's Avatar
I was speaking of this one:
http://www.gtspec.com/index.php?nav=...id=144&cat=153
But if the others work, and are less costly...then I would use them as well.
I thought some people had used the GT Spec ones in the past...and was calling on them for input.
Thanks for your links...more to look into.
-s-
Old 08-04-2008, 06:49 AM
earth0's Avatar
Oh,My bad. Thanks..for the link,now we gonna have new toy.
Old 08-04-2008, 12:11 PM
kool_yaar's Avatar
^ true but first we would have to confrim that it will fit the 07+ sedans as it MIGHT have diffirent mounting points(that i doubt) but still be sure before you order.... and yes that should help you with the body flex issue that you're having as our cars have no bracing in the center of the car which flexes the most so that should tighten things up a bit G/L
Old 08-04-2008, 12:35 PM
sredish's Avatar
that's not a ladder bar and it's not for the 350z and G35 coupe, not 07+ sedan; however this lower tie brace will fit the sedan:
http://www.gtspec.com/index.php?nav=...id=153&cat=153
And I have the Tanabe under brace here to install.
Old 08-04-2008, 01:39 PM
ParkStr8's Avatar
I just spoke to GT Spec and they will have all the production braces available next month for our Gen G35 sedans. They have to finish fit and test on the mid chassis, but the others are completed.
So I guess I'm waiting until then as what I really need is the mid chassis.
I'll post when/if I know more.
-s-
Old 08-11-2008, 06:29 PM
ParkStr8's Avatar
Bump...question...will the center chassis brace be enough, or do you guys think I need the other bars from GT Spec or Tanabe?
This is my daily as i'm buying a 350Z as my toy.
Input?
Old 08-11-2008, 06:36 PM
Omegamerc's Avatar
Well on the new G's the only one that has those items right now is Paul(paulg35) Most of us have the gtspec front strut bar, which is an extremely well built unit that does what it should w/ease.
Old 08-11-2008, 07:48 PM
sredish's Avatar
the GT Spec strut bar and the center chassis brace should be enough, but whatever under car bracing you get, I'd couple it with a strut tower brace. The strut tower brace will do more as one single item than the mid chassis brace will, together they should work well.
Old 08-11-2008, 11:43 PM
ParkStr8's Avatar
Ok...so i'm getting I should get both the mid chassis AND the Strut bar. If I get the strut brace now, will that help with the body flex that is making the front/rear windshield creak? Or jsut upgrade the suspension travel?
thanks for the explanations...every car I've had so far didn't really need one added. I did add one on my SRT8, but it made almost no difference.
Is the one you bought the GTS-SUS-1332?
Link: http://www.gtspec.com/index.php?nav=...id=290&cat=153
-s-
Old 08-12-2008, 01:06 AM
RyanFow's Avatar
this months modified mag has an article with the GTSpec for the G35
Old 08-13-2008, 05:09 PM
ParkStr8's Avatar
Cut and paste text or link?
thx
Quick Reply: GTSpec Ladder Bar
