What is the Wheel HP of our cars?
if we were to assume that a 5AT G has 18% drivetrain loss, then it makes approx. 250whp.
now assuming the S3 is also an auto, then with 18% drivetrain loss, whp would be around 209. which is still less than the G even after you remapped it. Plus your S3 is a quattro, which means your drivetrain loss is even greater.
So Robby, you never answerd my question earlier you got 310whp and 242tq from a CAI, and Headers? you have off next to them so I dunno if you have them on or off
Thanks man
Cool dude, so a simple re-map should get me somewhere into the 300 mark? shame the Torque couldn't be higher
^Tadashi at TS said you can get 10whp or 30+whp it just depends on the abuse the car has taken. Some people got 290whp and me and another guy got around the same number. I think his name is Brian.
The torque couldn't be brought up much cuz of my intakes
I think the stillen 3Gs will have better luck with this tune.
My Audi is an S3 and not an A4
lol. it is the old S3 (2002) so 1.8 Liter, K04 turbo, 4 cylinder 5 valve = 20valve engine block. Stock it was 225hp (not whp) after remapping i've taken it to 255hp (not whp) and 280tq (not whp)
standard the car will do 0-60mhp in 6.5-6.9 after remap its closer to 5.9. Now my confusion is how can a car that
- Weights more, the G35 is approx 1,600kg whereas the S3 is 1,450kg
- G35 has nearly the same HP and much less torque than the S3
- G35 is RWD whereas the S3 is quattro
now with all the above how in the world does a G35 do 0-60 in 5.9? when I can just about get my S3 to that figure??? or was the 5.9 figure also at crank? lol
lol. it is the old S3 (2002) so 1.8 Liter, K04 turbo, 4 cylinder 5 valve = 20valve engine block. Stock it was 225hp (not whp) after remapping i've taken it to 255hp (not whp) and 280tq (not whp)standard the car will do 0-60mhp in 6.5-6.9 after remap its closer to 5.9. Now my confusion is how can a car that
Don't get me wrong, the G feels fast, and I like it, but I expected it to be producing a bit more whp and torque than what most people have told me
, in a straight line race against the S3 yeah the G will win but only after 70mph and over, and on take off the G will eat the S3 dust, so is the 0-60 time of 5.9 also wrong?
Ya it did.
Tadashi, the guy who did the reflash on my car, personally hates aftermarket intakes. He prefers the stock ones with K&N drop in's. But since he herd about the new stillen 3G's, I think he changed his mind lol
I might get the stillen 3G's.
It doesn't - as someone said below, the G35 goes 0-60 in around 5.3. Much faster than your stated numbers for the S3. BTW, your torque numbers are...surprising, even for a turbo car. 1.8L is really small in the scheme of things, are you sure that number is correct? If none of those numbers are WHP, how'd you get them (clearly not a dyno)??
Again, your numbers are wrong. And based on 1/4 times at the track, the G is likely to keep going.
Humm, good thing I held back because I was about to get them. I guess I'll wait for more reviews about the Stillens and then see
rezendvous420
May 31, 2020 01:26 PM
Brodys_GCoupe
Nov 7, 2015 08:06 PM
