No colour in the main screen on DVD
i installed a rear camera through the sockets in the armrest but the picture is coming black and white then i checked with a portable DVD player and again it was black and white....anyone knows why i cant get colour on the NAV screen...my car is without factory Sat NAV.
The only thing that comes to mind are playing with the settings for color, brightness , tint, etc...
Do your radio and A/C screens have color?
Maybe try another cable or wiggling the cable connection a little just to see what happens.
havent tried wiggling the cable....i will check that
Not sure how electronics savy you are but here are some drawings I found for troubleshooting. Seems to need an O-scope for one part of it. I would be of no help here. It seems like the only thing that Infiniti suggests to troubleshoot is the OEM wiring, the display, the video device (which you have already tested). Maybe just take to dealership?
thanks...you mean from the device??? is there any option like this for the screen
...what exactly you mean by need an O-scope and for which part??
The NTSC vs PAL setting was really a great idea, I hope that I didn't come across as being sarcastic. I beleive the setting would be on the video device itself. Most things in the US are only in NTSC but sometimes a device will have the option to select the European standard which is PAL. This could be an electronic menu setting or a physical switch on the device.
Good luck!
Did you try looking for a NTSC/PAL switch or setting? Otherwise I am drawing a blank. Maybe it is time to just bring it in. If the car is under 60k miles then it is still under warranty.
Another thing to try is reposting in the 07+ or 07+ tech forum. Because your original thead got moved, it is not getting bumped to the top of the forum list when people respond so you are probably not getting a lot of viewer traffic. Good luck!
BradMD_96
Oct 6, 2015 09:31 AM
Brilliant!
