What is the metal mesh thing? Can i just cut it off?
Old Mar 1, 2009 | 01:31 AM
  #46
Csquared's Avatar
It's more fun part by part also I was thinking of doing a custom job for the mid pipe, I like the sound of the Tanabes
Old Mar 5, 2009 | 05:30 PM
  #47
SavageHenry's Avatar
I've had my Fast Intentions HFC's installed for a few months now and I get more of a fine high pitched rattle now. I took it to a local shop and narrowed the sound to my heat shield at first. I took that off and it really helped. Now all I get is a buzzing sound. When we put it back on the lift we could definately see the sound coming from the flex joint.
Now I'm throwing a code from my cats. Does anyone know how to fix that? I took it too the dealership and they said it was because of the aftermarket cats.
thanks
Old Mar 5, 2009 | 05:57 PM
  #48
Csquared's Avatar
Hmm guess I'll need a new y pipe!! Call FI and get Anti foulers for the Sensors
Old Mar 27, 2009 | 02:33 PM
  #49
Csquared's Avatar
I read that Flex pipes are needed for transverse mounted engines, are out engine transverse mounted?
Old Mar 27, 2009 | 03:20 PM
  #50
tonke73's Avatar
No, transverse mounted engines are normally for front engine drive vehicles.
A transverse engine is an engine in which the crankshaft is oriented side-to-side relative to the length of the vehicle. This is also sometimes called an east-west engine. Most modern front wheel drive vehicles use this engine orientation (with the exception of some Audis), while most rear wheel drive vehicles use a front-to-back longitudinal arrangement.
Old Mar 27, 2009 | 03:24 PM
  #51
dofu's Avatar
20 Year Member
thanks
Google the term "non foulers"
That's most likely your solution. But if you can tell us what the code is for exactly, we might be able to give you a better answer just in case this isn't the issue.
Old Mar 27, 2009 | 05:33 PM
  #52
Csquared's Avatar
Thanks tonke, I found out that this hissing sound is coming from the Flex pipe, I wrapped a wet towel over it and it muffled out the sound pretty good. Should i just header wrap the joint? Also like i said earlier it said that flex joints are mainly for transverse mounted engines and since we established that our engines isn't transverse mounted and there doesn't seem to be much movement in the exhaust pipes would it be okay to cut these out?
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
pasjr1972
Sep 1, 2015 10:17 PM
Jiggerjuice
Aug 31, 2015 11:49 AM
Frostbite91
Aug 20, 2015 07:20 PM
Cam_Cooper3
Aug 4, 2015 01:53 PM
