Intelligent Key Low Battery Warning
Old Mar 4, 2009 | 09:23 AM
C5TOG35's Avatar
I received the low battery warning and changed out the battery in my fob. I cannot get rid of the low battery warning message upon startup. Has anyone else encountered this problem?
Old Mar 4, 2009 | 09:52 AM
terrycs's Avatar
Sorry, I have to ask the obvious first ... Does your OTHER i-key clear the warning light? Is the new battery installed and oriented correctly? Is the new battery "good" (checked voltage output)?
Old Mar 4, 2009 | 12:04 PM
C5TOG35's Avatar
New Battery from a sealed pack, installed correctly. I am at work and have not had the opportunity to try the other key.
Old Mar 9, 2009 | 04:07 PM
airhoppz's Avatar
Someone told me the key fob can be charged up by putting it in the slot. I think it's BS but I've been too lazy to pull out the manual.
Old Mar 9, 2009 | 04:11 PM
darkbrown1's Avatar
I have an 08 Maxima with the intelligent key......
Are you guys saying that when the battery from the key fob goes bad it will alert u from the instrument panel on the dash ?????
Old Mar 9, 2009 | 07:41 PM
AesonVirus's Avatar
Yes, the center display on the gauge cluster alerts you with a low battery message, allowing you to buy a new battery before it's completely dead.
Old Mar 9, 2009 | 07:42 PM
AesonVirus's Avatar
Complete and total BS.
Old Mar 10, 2009 | 01:59 AM
PeterUbers's Avatar
CTO:
Another member recently had a similar issue, he replaced the battery, confirmed it was the right side up -- the battery low battery light cleared after a few start-up cycles ... but it didn't clear for him right away.
I wonder if you'll have similar luck.
Old Mar 11, 2009 | 04:04 PM
airhoppz's Avatar
I figured it was BS. Now only to figure out how to open up the I-Key!
Old Mar 11, 2009 | 04:09 PM
AesonVirus's Avatar
Pull the emergency key out of the fob.
Look at the flat end of the fob and you will see a tiny notch... and the line between the two sides that make up the front and back sides of the fob.
Use a tiny screwdriver and it just pops apart.
There's insturctions and a little diagram in the manual as well.
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
EasySausage
Sep 24, 2015 01:06 PM
gatorglaze
Sep 10, 2015 12:03 PM
Jnm07
Sep 5, 2015 01:16 AM
pasjr1972
Sep 1, 2015 10:17 PM
