07 infiniti g35x VDC & slip light stay on ?
Old Nov 9, 2010 | 10:20 AM
bns11901's Avatar
Hey, I have an 07 infinit g35x sedan and recently when I start my car and start driving my brake light pops up if I take off slightly fast. This light doesn't go off untill I come to a complete stop.
Now if I do not stop soon enough with the brake light on my VDC light and SLIP light come up and do not turn off unless I shut down and restart my car.
BTW: this happens every time I drive my car.
If anyone has any tips or information on this issue I am having that would be great!
Thank you!
Old Nov 9, 2010 | 11:09 AM
tg1234's Avatar
Search would be your best option. This comes up once a week.
You need a brake job soon.
Old Nov 10, 2010 | 12:14 PM
djfarhan's Avatar
https://g35driver.com/forums/v36-bra...ts-coming.html
Old Nov 26, 2010 | 10:43 AM
sprintsix's Avatar
Check you fluid level, too. Low fluid will make the indicator light go on when accelerating because the fluid sloshes.
Old Dec 27, 2010 | 04:18 PM
kingen's Avatar
VDC Slip and Brake Lights ON
I have recently experienced this problem and finally called the dealer to see if he could provide any insight. He said that while it may mean that these systems are all related and while I may be ready for new brake pads, the first thing I should check is the brake fluid level. Sure enough, it was on the low side so I filled it up. That was about three weeks ago and the lights have not come on again.
Anyone who experiences this problems should first check the fluid level and fill if needed. This $4 fix could save you hundreds of dollars.
Old Dec 27, 2010 | 04:53 PM
LakeShore_Slate's Avatar
Originally Posted by sprintsix
check you fluid level, too. Low fluid will make the indicator light go on when accelerating because the fluid sloshes.
+10
Old Jan 29, 2011 | 01:12 AM
Ahmad_1290's Avatar
Same thing happened to me, I was low on brake fluid
Old Jun 30, 2011 | 10:14 AM
3lpaisa's Avatar
It started doin that after I got my 20" rims so I think it has to. Do with weight an alignment
Old Sep 16, 2011 | 10:18 AM
Scarface0329's Avatar
Thank You
Hey guys..I had the exact same problem with my 2007 G35x. I filled up my brake fluid and it fixed the problem. Thanks!!!
Old Dec 4, 2011 | 02:29 PM
Feeelax's Avatar
Sorry but I have tor resurrect. Just got the light on a few days ago and needed a recommendation on what brake fluid to get? or to simply bring it to the dealer to do it for me.
Old Dec 4, 2011 | 07:19 PM
djfarhan's Avatar
any brake fluid shoudl do it
Old Dec 4, 2011 | 07:37 PM
Supremee's Avatar
your brake fluid doesnt go low on its own -_- its dues to break pads going. Early warning. So start saving for brake pads lol
Old Dec 4, 2011 | 08:04 PM
mdcdvm's Avatar
Absolutely. I had same problem, rear pads were very low. Didn't need fluid as replacing pads "topped it off".
Old Dec 4, 2011 | 08:07 PM
vqsmile's Avatar
as long as it's DOT 3
Old Dec 5, 2011 | 01:48 PM
Feeelax's Avatar
Ty sir.
and about those pads. I'll change em when the light returns lol
Hasanbaloch
Feb 29, 2024 08:45 PM
Mry
Mar 3, 2023 01:03 AM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
newg37
Jul 26, 2015 09:32 AM
