Automatic transmission fluid change....help me make a diy
Old Mar 15, 2011 | 02:46 AM
  #31
monsta717's Avatar
when you check the Tranny level from the stick, are we suppost to have the engine running, or engine off is fine?
Old Mar 15, 2011 | 11:40 AM
  #32
kool_yaar's Avatar
engine should be running and car on a level service as per the FSM.
Old Mar 16, 2011 | 09:48 AM
  #33
mifesto's Avatar
https://g35driver.com/forums/v36-diy...uid-drain.html
i did a fully comprehensive writeup back in november, covers AT, tcase, rear diff AND front diff.... guess no one read it lol.
Old Mar 16, 2011 | 02:36 PM
  #34
surma884's Avatar
Yes, but pictures help a lot. infinitihelp.com has videos on it I think.
Old Mar 17, 2011 | 08:58 AM
  #35
mifesto's Avatar
it does have video but only for the rear diff and AT if my memory serves me right... for anyone with AWD, there wasnt any comprehensive howto on front diff and tcase steps.... even more difficult to find howto on 2007-2008 g35 awd
i promise next time i do all my steps again, ill take pics hehe
Old Mar 17, 2011 | 05:35 PM
  #36
boostd7's Avatar
[QUOTE=mifesto;5747973]it does have video but only for the rear diff and AT if my memory serves me right... for anyone with AWD, there wasnt any comprehensive howto on front diff and tcase steps.... even more difficult to find howto on 2007-2008 g35 awd
When I tried to do mine I couldn't find anything. So I asked for people to help me come up with a semi- diy with pics. this thread should cover all the fluids minus the coolant. I am going to swap out the coolant sometime this month and add more pictures on here. kevin
I
Old Feb 7, 2012 | 11:25 AM
  #37
MikeGrote's Avatar
so which is the trans send and trans return on my 06 g35 coupe? here is a picture...
Old Mar 25, 2015 | 02:58 AM
  #38
SoCal G 35's Avatar
Why wasn't the filter changed on the oil pan ?????
Old May 27, 2015 | 11:54 PM
  #39
miamichillin99's Avatar
I can't tell from the pics which is the correct line to flush ATF from? Also once you disconnect the hose does it drain from the hose or from the metal tube? Lastly how many quarts are needed for a 2006 g35x AWD?
Old Jun 22, 2015 | 08:01 AM
  #40
youngdip631's Avatar
I want to get this done on my 07 4dr X, im only gonna need 11 quarts right? Where would be the cheapest place to buy it? And what about powersteering and differential fluids?
Old Nov 1, 2015 | 06:51 PM
  #41
berdyev's Avatar
This looks like a lot of work. Holy *****
Old Sep 27, 2016 | 07:05 PM
  #42
cecobb's Avatar
Transmission fluid change
Originally Posted by boostd7
next project......transfer case and rad. who wants to help? I m in abingdon maryland.
Just read your info on trans fluid change. Any problems with it after changing fluid. I have 75k on mine and never been done. I'm also in abingdon Md. Thanks.
saskicker32
Aug 11, 2015 02:12 PM
Srinidhi
Aug 7, 2015 03:38 PM
newg37
Jul 26, 2015 09:32 AM
newbdriver01
Jul 15, 2015 06:10 PM
