07 S Sedan Intelli key issues
Old Sep 19, 2018 | 07:45 PM
Reardo's Avatar
Been searching on this for years and am at my end of my ropes.
I have replaced aced all batteries in my fobs and the car.
Heres what happens:
1. Orange key light will come on
2. When light is on my headlights come on, my ac compressor turns off, the cooling fan goes high speed, and my wipers stop working
3. I hit the steering wheel a few times
4. Light turns off and everything goes back to normal
5. After a few seconds the process repeats
ive pulled the steering lock and it still does the same thing.
Any my other thoughts or suggestions? I’m thinking of replacing the clock spring to see if maybe it’s that but who knows
thanks
Old Sep 20, 2018 | 11:47 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Does this happen while driving? Can you reproduce the issue with the physical key in the ignition?
Old Sep 20, 2018 | 02:45 PM
Reardo's Avatar
yes it it happens when driving. It also happens when I have the intelli key in the dock.
It it seems to only happen during the day as well. I tried covering over the auto sensor for the lights and to just turn the lights on manually, but same thing.
Old Sep 20, 2018 | 06:45 PM
cleric670's Avatar
BANNED!!!
Unfortunately this sounds like a failing BCM, I would clean up the power system first, the primary and ground wire on BOTH ENDS of the cable on the battery. I would also remove the instrument cluster and the stereo/AC face and check the two ground wires that are behind it just to rule out a simple electrical issue.
If that doesn't fix I would go to Nissan for a diagnostic.
cb4h
Nov 5, 2009 03:03 PM
GMax
Nov 26, 2008 10:04 PM
Newg35coupe
Oct 20, 2006 12:45 AM
OhNelly
Jul 15, 2005 08:15 AM
BobbyG123
Feb 24, 2005 05:13 PM
