A/C doesn’t blow cold air - used 2007 g35x
Old May 18, 2019 | 04:39 AM
hardus77's Avatar
xnz
Hello everyone,
Car has been great otherwise feel welcomed in the Infiniti family but now that weather is warming up i just now noticed that the AC doesn’t work the way it’s supposed to. Climate set to 60 degrees with AC toggled on only gives the same temperature air. Heat works. After 20 minutes air is still same temperature when set at 60. Just recently replaced a relay plug for the fan blower and that was an easy fix but now I found this out and don’t know what to do about it.
Anyone happen to know what the cause of this is? Any help is appreciated.
Old May 18, 2019 | 07:20 AM
telcoman's Avatar
Veteran: Army
Originally Posted by hardus77
Hello everyone,
Have the AC system checked for any freon leaks.
Telcoman
Old Nov 29, 2019 | 11:34 PM
Serge Mullen's Avatar
Mine went out as well earlier this year. I added some r134 refrigerant and it started to work fine, but last time I tried it (two month ago) it was blowing nasty warm air. I'd say leak somewhere, might cost a few hundred to get it fixed or just keep adding a can of refrigerant every three months..
Old Jul 20, 2021 | 09:47 PM
Ponyryd's Avatar
G35x
Best to have a pro check it out, I changed my compressor a month ago for the same issue, but a/c has a lot of things that can fail, best not to guess.
jrongish
Sep 7, 2017 05:07 PM
master111
Sep 25, 2015 08:32 PM
dahurt45
Jul 14, 2009 02:26 PM
ilyaat
Sep 13, 2007 07:06 PM
VancouverG88
Aug 1, 2007 02:58 AM
