Why no LED rear turn signals?
#31
Originally Posted by psedog
Looks like you don't need a load resistor. They look just right. Where did you get your bulbs? Also, I agree the red LED's look much better.
www.superbrightleds.com
The load resistor should be in next week and I will let you know if that rectified the problem.
#32
You can't in this thread. Look at the bottom of the page and you will see
When HTML code is Off you can't embed videos into the thread.
If you ever want to in a thread that has HTML code On, just grab the HTML tag information and paste it into the message.
The code will look like this
<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://i226.photobucket.com/player.swf?file=http://vid226.photobucket.com/albums/dd149/cnugs127/RegLight-RedLED.flv"></embed>
#34
Originally Posted by cnugs127
Actually, i do need the load resistors. They look perfect when the hazards are on but signaling left or right will make the blinkers flash rapidly. I ordered the bulbs and load resistor from
#35
#36
#37
#38
Oh no! I've heard that superbrightleds tend to die in a relatively short amount of time (0 to 2 months). Hopefully they have fixed those problems. I'd hate to hear of another G owner getting burned.
#40
#42
Originally Posted by CoppellStereo
has anyone replaced the license plate lights to LED? i was thinking about buying the red LEDs for my brake lights that cnugs used as well as license plate lights? do you know what bulb will fit there?
#43
MyfistYourFace
08-08-2015 11:58 AM
