V36 Interior, Exterior & Lighting Interior & Exterior - Tech, Modifications, Lighting, Gauges and More
Anyone Remove Front Bumper?
Old Oct 14, 2007 | 04:17 AM
Stryatch's Avatar
I just spent 445.00 on buying and spraying a new front bumper for my blue slate G35 sedan because of a flying metal object on the freeway. Anyone have detailed instructions on removing the front bumper? I do it to my Z all the time and I assume they are similiar, but I want to know for sure how to do it. Can anyone help?? I don't want to spend another 3 bills in 'labor' at my dealership!
Thanks,
Stretch
Old Oct 14, 2007 | 04:21 AM
scarface_613's Avatar
sure i think i could help you out i;ve done a FEW times
Procedure:
Take off all plastic tabs that hold bumper on car.......remove all of the bottom screws that hold bumper....turn wheel to the right and then peel back the plastic and there is two bolts in there that you have to loosen(dont forget to remove your corners first), then turn the wheel to the left and do the same thing....once those are all taken off the bumper is free for you to take off........ I hope that helps you out.
Old Oct 14, 2007 | 04:30 AM
prelude555's Avatar
^^ everything he said and also one more screw hidden behind the plastic liner. its where the fender/bumper/headlight meets. pull the rubber piece back and you'll see a hidden 10mm bolt holding the bumper from the fender.
Old Oct 15, 2007 | 12:57 PM
Stryatch's Avatar
Thanks guys...none of you have the diagram from the manual, just so I don't mess it up? It kinda sounds exactly like my Z though. I really appreciate the feedback!
Stryatch
Old Oct 15, 2007 | 01:03 PM
ABNERG35's Avatar
G-SMACK THIS
YOU CAN VIEW PICTURES AT
http://www.advancedautomotiveconcepts.com/
ONLY A FEW PICS BUT THEY MAY HELP. CLICK ENTER AND THAN GALLERY, INFINITI G35 COUPE. REMOVED MINE A FEW TIMES TO STICK IN THE HALOS
Old Oct 15, 2007 | 01:44 PM
viguera's Avatar
Procedure:
As you said "remove your corners" I gather you're not talking about an 07.
I'd ask that dude that just added the foglights... Obviously he just took his off.
Old Oct 15, 2007 | 02:11 PM
Hi-TechG35's Avatar
To remove the two screws in the bumper in the wheel well would be much easier if you just take the wheel off. That way you have more room to manuver the ratchet.
Old Oct 16, 2007 | 12:54 PM
Stryatch's Avatar
07 Sedan
I appreciate all the pics and advice guys, but they are for the wrong model year. As i said before, I can probably figure it out, but if anyone has removed an '07 bumper, explaining where the bolts are that I can't readily see is the most important part so I don't have to dig around...On my Z I never had to remove my wheels, you can just turn the wheel left and right to access the bolts. I'm looking for someone who removed their '07 sedan bumper...Anyone?
thanks!
Stretch
Old Oct 16, 2007 | 12:57 PM
Stryatch's Avatar
'07 sedan
thanks!
Stretch
Old Oct 16, 2007 | 01:31 PM
TheIvoryG's Avatar
Did you try this thread yet?
https://g35driver.com/forums/g35-sedan-v36-2007-08/173228-custom-foglights-w-lots-pix.html
Old Oct 17, 2007 | 03:10 AM
Stryatch's Avatar
Thanks!...I guess its exactly like the Z...2 bolts behind each fender guard and 10 bolts underneath and the stupid little plastic clips on top... Should be easy!
Old Mar 5, 2022 | 11:42 PM
VQ35HRMike's Avatar
2007 G35 sedan sport
Question
hey bro i know Im a few years late(almost 15-16)... but was it easy? im ordering a new bumper and i wanna know if i could do it myself. lmao might be hard to remember tho i wouldnt even expect u to answer lmao
Tukeeg35
Sep 27, 2015 12:16 AM
derres
Aug 28, 2015 03:27 PM
Nick_M
Aug 3, 2015 11:08 PM
Nick_M
Aug 3, 2015 05:33 PM
st33zygill
Jul 29, 2015 10:05 PM
