snow tires
snow tires
its still the summer but this is a hard choice...i have an 06 with 19 stock rims this is the problem in the winter i dont know if im going to get snow tires for the stock rims and buy a set of 20's for the summer or keep the stock wheels and get pos rims for the winter...annyyy ideass??????
what i was thinking about doing is using my 19 w/ winter tires and getting these for the summer http://www.1010tires.com/wheel.asp?i...+Touring+Sport how do you think snow tires on stock 19in wheels would be in the snow...since there sooooo wide and how much do u think these would cost last year we didnt have 2 bad of a winter in ny but any snow with these stock tires my car is useless
Originally Posted by ericsherbrooke
18 inches winter tires are overpriced almost useless in the snow, I cannot imagine 19 inches...
(I live in quebec, Canada)
And if you search you will find, I purchased used 4 winter tires with 4 OEM 18s for under $600. And you can find same deals for the summer tires, since I bought 4 used rear michelins for the summer for under $300. Good luck everyone, have fun and be smart and safe.
Originally Posted by TheKnite
Your comment is useless. No hard feelings, but I have stock 18s, with winter tires, and they were amazing in the snow. Would recommend it to everyone, since you still keep your ride looking good, while you plow thru the snow.
Come on, I said IN QUEBEC CANADA, Blizzack lm22 in 18 inches size around here cost around 500$ a piece + taxessss in canadian money$$$
We get -30 degrees celsius regulary around here with snow drop that can reach 12 inches overnight during winter.
I do not recommend using this type of setup in my region, even with that amount of money in tires car cannot climb steep entrance because tires are so wide they get full of snow, loose grip and then VDC kick's in and stop car movement.
The point is what is YOUR definition of snow.
Next year I go with a set of 17 inches rims that clear the brembo to get a higher tire profile and narrower tire to slice through snow.
I am looking to buy a set from the US but the shipping is killing the deal...
(BTW, I speek french, sorry if my english look's strange to you...)
i kept the original 19s as my summer setup and picked up 17s with snow tires for the winter setup. 4 rims and 4 tires including cost of mounting cost me $1000.
with our cars you are better of with a winter setup, the rear wheel drive in the snow can be scary...
btw i got the above deal from tirerack.com
